    [Plugin]ContextMenuOptimizer v2.8 (menu gray-out issue fix)
    36 Posts 7 Posters 59.2k Views 7 Watching
      craigbic
      thomthom, I am still having the problem after updating Fredo's plugins. I do have quite a large collection of plugins that I use so I have learned to live with the context menu gray-out by going to the selection menu under Edit (not sure what this menu is actually called - Edit context menu? - so see 1st screen shot).
      http://archlight.files.wordpress.com/2010/06/edit_contextmenu_thumb.jpg
      Can go here instead of right-click context menu if it is grayed out
      http://archlight.files.wordpress.com/2010/06/plugin_running_thumb.jpg
      Alex, your plugin is installed properly and is running
      Alex, I installed your plugin, it is running (see second screen shot) but I am still having the context menu gray-out issue, at least in part (see third screen shot). Most of the options I use such as "Explode" are grayed out.
      http://archlight.files.wordpress.com/2010/06/stillgrayedout_thumb.jpg
      Right-click context menu is still grayed out to some degree
      I'll keep using the Edit menu for now. Just thought you might appreciate the feedback. Thank you for all the hard work! ๐Ÿ˜„ I hope this annoying problem goes away along with toolbar migration. ๐Ÿ˜ฎ
      Checkout the Sketchup Graphics Blog at http://sketchupgraphics.com
      • kenK Offline
        ken
        @alexmozg said:
        @thomthom said:
        Alex, this debug mode: can that help Ken work out which plugin greys out the menus?
        Debugging is for informational purposes and shows the number of objects (Sketchup::Menu, UI::Command) available in the current object space.
        Default debug info is off.
        I think my plugin will solve the Ken's problem.
        Note: I haven't had the problem since I reload only the plugins I wish to use. I am no longer a plugin groupie. I am being careful, not to have multi plugins for the same purpose. So here is hoping I have solved my problem just by not being a plugin in hog.
        Tom thanks for the help and Alex thanks for the plugin. If I have a re-occurrence of the problem, I know where I will head.
        Ken
          AlexMozg
          The menu buffer overflows anyway if the number of objects UI::Command becomes more then 500-600!
          And unfortunately, the predefined context menu commands
          (such as Explode, Hide, Erace etc.)
          are not amenable to correction ๐Ÿ˜ž,
          but the commands of other plugins should always work ๐Ÿ˜„.
          craigbic
          โ— In your case, you can only limit the number of plugins which you use.
            So it's not really the fixed 1000 that Google said?
              craigbic
              craigbic
              Limit plugins? NEVER! Not a big deal - just an annoyance really. Thank you for the explanation and the plugin! Good work! ๐Ÿ˜Ž
                AlexMozg
                Maybe...
                500-600 for Sketchup 5, I have been tested it.
                • CadFatherC Offline
                  CadFather
                  Thom, i'm quite sure the selection toys are causing the issue on my pc - so the google fix is not working after all
                  when i remove S.T. the menu does not grey out even after hours of working ๐Ÿ˜’
                    That is very odd. I can not reproduce it. Nor does it have the code that Google said caused this.
                    How many plugins had you got installed? I wonder if one might run into this if one just has many menu items - Selection Toys has quite a few. Have you tried disabling some of the menu items?
                      CadFather
                      thanks that's a good idea, might just be it...well hope so.. after all together there must be something like 500 or 600 plugins in there by now.. ๐Ÿ˜Ž
                        โ— โ— โ—
                        Well - that might very likely be the cause. Google said their limit of Command objects where at about 1000 - if you ahve that many you might hit some limit even without some leak like Fredo's tools.
                        What would be interesting is if you could install one more. (No worries no menus or anything ๐Ÿ˜‰ )
                        Then open your Ruby Console and type in stats - see what it reports.
                        Then do some right clicks and see what it reports afterwards.
                        tt_stats.rb
                          CadFather
                          well, 600 was my very quick estimate of all the commands in the folder from didier's spray comps to su2kt
                          but the stats gives this: (cool thing) - UI:Command objects: 283 of 1000 (28.30%)
                          so i guess that's still not too greedy..
                            Does it increase during usage? After right-clicking for instance?
                              CadFather
                              not for the moment - i think it needs more work-time - i'll put it through the paces this afternoon though.
                              to be continued.. ๐Ÿ‘
                                Then it can't be the same issue, because you should see increase immediately. (However, you might get different results from what you right click on, Edge,Face,Group,Component.)
                                  CadFather
                                  i see.. i shall let you know how i get on, i have some work later so i will be able to test it properly..
                                  meantime i disabled the selection toys i don't use so much, so i'm preparing for sunshine through the clouds! ๐Ÿ˜„ โ˜€
                                    AlexMozg
                                    CadFather
                                    Do you use my plugin?
                                    I think it should solve such issues.
                                      CadFather
                                      hi Alex
                                      yes i did as soon as i saw it.. but the result was that only some menus 'refreshed' - some other (strangely the sketchup ones like activate section plane, reverse face etc) were still grey ๐Ÿ˜•
                                        AlexMozg
                                        @cadfather said:
                                        hi Alex
                                        My plugin does not allow a possible memory leak, it protects the buffer menu.
                                        And I wrote about it:
                                        @alexmozg said:
                                        ...unfortunately, the predefined context menu commands
                                        are not amenable to correction,
                                        but the commands of other plugins should always work.
                                        My colleagues and I use my plugin and we are not experienced this issue any more. But we have limit plugins in use, basically most necessary.
                                          chango70
                                          OMG all my menus are greyed out from the start with or without this plugin!!! What is going on?
                                            You may have too many context-menu / commands running - do you have many plugins ?
                                            Temporarily remove any you recently added and see what happens...
