    [Plugin]ContextMenuOptimizer v2.8 (menu gray-out issue fix)
    36 Posts 7 Posters 59.4k Views 7 Watching
    • kenK
      ken
      @thomthom said:
      That's might interesting.
      But has anyone experienced any other than Fredo's old plugins to cause the greyouts? After updating his tools I've not experienced this issue any more.
      Yes, I had the greyouts after installing Fredo's new plugin. However, I had just about every plugin there was. So I removed all plugins, loaded only the one I really wanted. Tried to elimate all plugins that called the content menu if I could. I even removed the content menu selection from some plugins. And plugins that had a toolbar and also listed in the plugin or contents menu selections, I would remove these two choice and only use the toolbar.
      So far I have not had the trouble happen. Note, that I don't have 1/2 the menu's that I had before.
      Ken
        Alex, this debug mode: can that help Ken work out which plugin greys out the menus?
          AlexMozg
          Debugging is for informational purposes and shows the number of objects (Sketchup::Menu, UI::Command) available in the current object space.
          Default debug info is off.
          I think my plugin will solve the Ken's problem.
          • C
            craigbic
            thomthom, I am still having the problem after updating Fredo's plugins. I do have quite a large collection of plugins that I use so I have learned to live with the context menu gray-out by going to the selection menu under Edit (not sure what this menu is actually called - Edit context menu? - so see 1st screen shot).
            http://archlight.files.wordpress.com/2010/06/edit_contextmenu_thumb.jpg
            Can go here instead of right-click context menu if it is grayed out
            http://archlight.files.wordpress.com/2010/06/plugin_running_thumb.jpg
            Alex, your plugin is installed properly and is running
            Alex, I installed your plugin, it is running (see second screen shot) but I am still having the context menu gray-out issue, at least in part (see third screen shot). Most of the options I use such as "Explode" are grayed out.
            http://archlight.files.wordpress.com/2010/06/stillgrayedout_thumb.jpg
            Right-click context menu is still grayed out to some degree
            I'll keep using the Edit menu for now. Just thought you might appreciate the feedback. Thank you for all the hard work! ๐Ÿ˜„ I hope this annoying problem goes away along with toolbar migration. ๐Ÿ˜ฎ
            Checkout the Sketchup Graphics Blog at http://sketchupgraphics.com
            • kenK
              ken
              Note: I haven't had the problem since I reload only the plugins I wish to use. I am no longer a plugin groupie. I am being careful, not to have multi plugins for the same purpose. So here is hoping I have solved my problem just by not being a plugin in hog.
              Tom thanks for the help and Alex thanks for the plugin. If I have a re-occurrence of the problem, I know where I will head.
              Ken
                AlexMozg
                The menu buffer overflows anyway if the number of objects UI::Command becomes more then 500-600!
                And unfortunately, the predefined context menu commands
                (such as Explode, Hide, Erace etc.)
                are not amenable to correction ๐Ÿ˜ž,
                but the commands of other plugins should always work ๐Ÿ˜„.
                craigbic
                โ— In your case, you can only limit the number of plugins which you use.
                  So it's not really the fixed 1000 that Google said?
                  • C
                    craigbic
                    craigbic
                    Limit plugins? NEVER! Not a big deal - just an annoyance really. Thank you for the explanation and the plugin! Good work! ๐Ÿ˜Ž
                      AlexMozg
                      Maybe...
                      500-600 for Sketchup 5, I have been tested it.
                      • CadFatherC
                        CadFather
                        Thom, i'm quite sure the selection toys are causing the issue on my pc - so the google fix is not working after all
                        when i remove S.T. the menu does not grey out even after hours of working ๐Ÿ˜’
                          That is very odd. I can not reproduce it. Nor does it have the code that Google said caused this.
                          How many plugins had you got installed? I wonder if one might run into this if one just has many menu items - Selection Toys has quite a few. Have you tried disabling some of the menu items?
                          • CadFatherC
                            CadFather
                            thanks that's a good idea, might just be it...well hope so.. after all together there must be something like 500 or 600 plugins in there by now.. ๐Ÿ˜Ž
                              โ— โ— โ—
                              Well - that might very likely be the cause. Google said their limit of Command objects where at about 1000 - if you ahve that many you might hit some limit even without some leak like Fredo's tools.
                              What would be interesting is if you could install one more. (No worries no menus or anything ๐Ÿ˜‰ )
                              Then open your Ruby Console and type in stats - see what it reports.
                              Then do some right clicks and see what it reports afterwards.
                              tt_stats.rb
                              • CadFatherC
                                CadFather
                                well, 600 was my very quick estimate of all the commands in the folder from didier's spray comps to su2kt
                                but the stats gives this: (cool thing) - UI:Command objects: 283 of 1000 (28.30%)
                                so i guess that's still not too greedy..
                                  Does it increase during usage? After right-clicking for instance?
                                  • CadFatherC
                                    CadFather
                                    not for the moment - i think it needs more work-time - i'll put it through the paces this afternoon though.
                                    to be continued.. ๐Ÿ‘
                                      Then it can't be the same issue, because you should see increase immediately. (However, you might get different results from what you right click on, Edge,Face,Group,Component.)
                                      • CadFatherC
                                        CadFather
                                        i see.. i shall let you know how i get on, i have some work later so i will be able to test it properly..
                                        meantime i disabled the selection toys i don't use so much, so i'm preparing for sunshine through the clouds! ๐Ÿ˜„ โ˜€
                                          AlexMozg
                                          CadFather
                                          Do you use my plugin?
                                          I think it should solve such issues.
                                          • CadFatherC
                                            CadFather
                                            hi Alex
                                            yes i did as soon as i saw it.. but the result was that only some menus 'refreshed' - some other (strangely the sketchup ones like activate section plane, reverse face etc) were still grey ๐Ÿ˜•
