Shape bend
downloaded shape bend, progress bar and message is No such file to load -- clf_shape_bender/clf_shape_bender.rbError Loading File clf_shape_bender_loader.rb
No such file to load -- clf_shape_bender/clf_shape_bender.rb,what do i do?i am using windows xp and version7pro
why not post this in the shape bender thread? you might have more luck.
Hi treb, that error generally means that you have not put the files in the correct place. The clf_shape_bender_loader.rb is the only file that goes into the base plugins folder. All other files belong in the sub folder clf_shape_bender. You should check on your unzipping software and make sure it is not flatting thew file structure when you unzip files. That is a common error that messes up plugin instlations. Good luck, let me know how it goes,
thanks for you quick response but,,,, ok ,i now have chris fllmers tools in plugins, select group, then shape bender, cursor changes to white arrow but it willnot select line on red axis, never get to start/end stage, help
Is
progressbar.rbnow in your Plugins folder - where it should be
yes , i have progress bar in the plugins folder
Make sure you have not changed your world axis. Right click on the axis and choose "reset" if it is an option. If it lets you reset it, than that means it was not displaying the correct axis. And shape bender only works on the original SketchUp axis. So once you reset it, then realign all the components and lines, etc. and try it again.
If "reset" is not an option, then that is not the problem. You could upload a small test model here and we can test it and see if can see what is going on. thanks!
hi everybody, i am amazed at your willingness to keep trying to help me and you have! i wound up downloading the progress bar , even though i already had it, but i think the first one was from an earlier version download, anyway , chris and tig thank you. the bend shape script is up and running and man is it fun, thank you again
Great, glad its working!
With your input, this post could be even better ๐
