    Vray's Limitation is SU (not a new statement)
    renderpluginsextensions
    16 Posts 3 Posters 4.3k Views 3 Watching
      @holmes1977 said:
      Model Stats
      Edges 2864
      Faces 923
      Components 136
      Groups 186
      Materials 87
      That can't be the full stats... in the Model Info -> Statistic window, make sure you tick "Show nested components"
      By the way, which version of VfSU do you use?
      • holmes1977H
        holmes1977
        Also there is no displacement. Im only using bump on the stacked brick.
        Exaggeration makes a dull story better.
        • holmes1977H
          holmes1977
          Hi Thom
          Model Stats
          Edges 2864
          Faces 923
          Components 136
          Groups 186
          Materials 87
          Files size is 22.5mb
          The largest material is the concrete driveway at 2550x3500 pixels at 2.89mb. Which is abit big but it is a large area.
          http://i607.photobucket.com/albums/tt154/holmes1977_album/Final_01_03copy.jpg
          Here is the image at 1024x768
          The IR setting for this are -4, -1. When I rendered at 3000x2250 and left the IR settings the same. So tonight I'll changeit to -6, -3.
          Thnaks again Thom your a star. I'll render this tonight and let you know how I get on.
          • holmes1977H
            holmes1977
            Whoops having a dumb moment
            Model Stats
            Edges 818932
            Faces 226155
            Components 500
            Groups 2151
            Materials 87
            That looks abit more like it. Tonight or this afternoon Ill render it again and see if chnging the IR settings helps. Otherwise I'll post all my settings.
            Im using the latest Vray.
            The last render I did had the RAM usage up at 3.24 gb, I was holding my breath waiting for it to crash but it didnt.
            Cheers mate
              You have mentioned "The latest Vray" as your VfSU version, can you be specific? There's been several times where people have thought to have the latest, while they actually did not. And I also don't know if that means the beta or not.
                Ah yea - the version number is now located under Preferences -> Extensions -> V-Ray for Sketchup
                There is an memory leak in this version however. So as you render after render you might find that memory is not released. Version .83 should be released right about now - but I'm not sure if it fixes the memory leak. But it does fix an array of other problems.
                • holmes1977H
                  holmes1977
                  Sorry Thom for being vague
                  The Vray version is 1.48.66
                  It dosnt say what version Vray is in the options anymore
                  So had to hunt for the installer.
                  Ive finished work and am about to test changing the IR settings.
                  • holmes1977H
                    holmes1977
                    You were total right about the IR settings
                    Im now rendering double the size of the last render at 4096x3072
                    and it is using a whole 1gb less memory.
                    I didnt realize that it would make that much difference.
                    Have you had any experience in printing large images. If you have, what
                    output size do you think I would need if I wanted to print to 1.2m x 2m?
                    Thanks again for your help Thom
                      rv1974
                      It's sad but VRAYforSU is the oxymoron. Use original max version.
                        It really depends on from where it will be seen. Such large images usually are seen from further away so one usually doesn't need the same resolution as A3/A4.
                        1.2m = ~47.24"
                        2.0m = ~78,74"
                        Say you print this in 100dpi - slightly larger than screen resolution:
                        47.24 * 100 = 4724
                        78,74 * 100 = 7874
                        But that might be very high resolution is you are at a distance.
                        1.2m x 2.0m has an aspect ratio of ~1,667
                        4096 x 3072 has an aspect ratio of ~1,333 - so that means some cropping must be done unless you change that.
                        Also, 1.2m x 2.0m is portrait, and 4096 x 3072 is landscape - so I'm not sure what orientation you are going for. ?
                        I'll assume the output to be 2.0m x 1.2m - landscape.
                        So if we use the full length of your render and print that to 2.0m, the resulting DPI is:
                        4096 / 78.74 = ~52.02dpi
                          Getting a Max license - not a cheap solution...
                          And as for the semantics: can't say I see how one can define "V-Ray for Sketchup" as an oxymoron.
                            rv1974
                            There are some good examples of oxymoron in english wiki that depict my statement qiute well: Serious Joke, Sweet sorrow, Happy depression... πŸ˜†
                              "Metaphoric oxymoron" ? πŸ˜‰
