    Tutorial - How to draw a hull
    28 Posts 7 Posters 8.7k Views 7 Watching
    • GaieusG
      And as for your hull questions (as I did not answer that part); best would be to upload that part of the model and people could chime in with different suggestions. There are a bunch of plugins that can help depending on what line structure you start from.
        Best plugs for this seems the collection of Extrude Edges Tools by Tig...
        Bon courage! ☀
        • G
          Gianluca
          Thank you charly2008! I'll try the program now! 😉
          • charly2008C
            charly2008
            If you've focused on the construction of ships, You should become familiar with the free version of the program Delftship. This program is ideal for the professional construction of ship hulls. I even had a couple of hours training to make hulls not yet perfect. See the link below.
            Karl
            404 Not Found
            (forums.sketchucation.com)
            Hull.skp
            • jgbJ
              jgb
              Ships and planes share the same SU design challenges.
              One tip: Best to work on a 1/2 hull as a component, then when done copy it abeam, flip it and move them together. Don't explode or merge them. Now any changes to one side is reflected on the other.
              jgb
              • charly2008C
                charly2008
                I forgot to mention that you can also export a half hull from Delftship.
                • GaieusG
                  Like the firsthalf above?
                  http://forums.sketchucation.com/download/file.php?id=49408&t=1
                  • charly2008C
                    charly2008
                    Half hull component
                    • G
                      Gianluca
                      How can i export the hull on SketchUp?
                      • X
                        xrok1
                        export DXF, import DXF. 😉
                        • G
                          Gianluca
                          Thank you! 😉
                          • G
                            Gianluca
                            How can i draw the hull of my ship under this face with DelftShip?
                            http://i49.tinypic.com/rcob9j.png
                            • charly2008C
                              charly2008
                              Hi Gianluca,
                              the best workflow is to import your shape as a background image in the plan view. There are many tutorials in th net see the links below.
                              http://www.google.de/url?sa=t&source=web&ct=res&cd=3&ved=0CCAQFjAC&url=http%3A%2F%2Fwww.boatdesign.net%2Fforums%2Fattachments%2Fdesign-software%2F33338d1248034181-step-step-design-your-boat-tutorial01.pdf&rct=j&q=delftship+tutorial&ei=A4wgTP-tDZyJONvj9B4&usg=AFQjCNFixMtN16ezIqLrCdCMdBpedUmw0Q.
                              http://www.modelboatmayhem.co.uk/forum/index.php?topic=19208.0
                              http://forum.woodenboat.com/showthread.php?t=90696
                              • G
                                Gianluca
                                Thank you Charlie2008! 😉
                                  Soap Skin and Bubble can make also half Hull 😉
                                  FOr the moment it's always free 😉
                                  • G
                                    Gianluca
                                    Yes, i have it! 😉
                                    Thanks for reply Pilou! 😉
                                    • charly2008C
                                      charly2008
                                      Here again the workflow:
                                      1. Export the model (in this the plan view, you can additional export the profile view) as image with dimensions from sketchup.
                                      2. Import the Image to Delftship. Place it at point of origin and then scale the image.
                                      3. Model the hull
                                      4. Export model as dxf and import into Sketchup
                                      • G
                                        Gianluca
                                        Thank you Charly2008! 😉
                                        I have only a question...How can i set the scale?
                                        • charly2008C
                                          charly2008
                                          Hi Gianluca
                                          1. Dimension the length and width of the new Model (Image 1)
                                          2. Right click at the plan view (Origin), Place the Image exactly left in the midth of the control frame(Image 2,3).
                                          3. Right click at the plan view (Set scale)and place the cursor exactly at the right end of the background image. In the control box adjust the length and hit ok (Image 4,5,6).
                                          Charly
                                          PS. In the first step is a mistake, instead of 2.16 the width (Beam) should be 2.18
                                          • H
                                            Howard leslie
                                            Gianluca,
                                            See this Tutorial, a method using using SketchUp only:
                                            http://forums.sketchucation.com/viewtopic.php?f=18&t=9652
                                            This Tutorial uses the SoapSkinBubble Ruby Script (Excellent) but you could also use:
                                            TIGs Extrude Tools or
                                            Fredo's Curviloft Tool (currently in development)
                                            Both are also excellent
                                            Hope this helps
                                            Howard L'
