    Tutorial - How to draw a hull
    28 Posts 7 Posters 7.8k Views 7 Watching
      Gianluca
      Hello all!
      I'm Gianluca and i,m 18 years old. I like Sketchup and i use it principally for draw ships..
      Sorry for my bad english but i'm italian! 😉
      Here some pics of my creations:
      http://i49.tinypic.com/5aj62v.png
      http://i48.tinypic.com/2lu599g.png
      http://i47.tinypic.com/rvk2f7.png
      http://i45.tinypic.com/t4xlpe.jpg
      Now, i have a question! 😄
      How can i draw this part of my ships? In italian i call it "the hull"..
      http://i48.tinypic.com/2ibfa8k.png
      Thanks for your help! 😉
        Hi Gianluca and welcome to SCF!
        I love ships myself (although prefer old sailing ships) and exactly know how it is to "fight" with SU while creating the hulls.
        You may be interested in Silver_Shadow's Eye Candy he posted a while ago...
          Gianluca
          Thanks for your answer Gaieus! The post is very interesting, it is a super model! Thanks again! 😉
            And as for your hull questions (as I did not answer that part); best would be to upload that part of the model and people could chime in with different suggestions. There are a bunch of plugins that can help depending on what line structure you start from.
              Best plugs for this seems the collection of Extrude Edges Tools by Tig...
              Bon courage! ☀
                Gianluca
                Thank you charly2008! I'll try the program now! 😉
                • charly2008C Offline
                  charly2008
                  If you've focused on the construction of ships, You should become familiar with the free version of the program Delftship. This program is ideal for the professional construction of ship hulls. I even had a couple of hours training to make hulls not yet perfect. See the link below.
                  Karl
                  http://forums.sketchucation.com/viewtopic.php?f=179&t=26870&p=235033&hilit=hulls#p235033
                  Hull.skp
                  • jgbJ Offline
                    jgb
                    Ships and planes share the same SU design challenges.
                    One tip: Best to work on a 1/2 hull as a component, then when done copy it abeam, flip it and move them together. Don't explode or merge them. Now any changes to one side is reflected on the other.
                    jgb
                      charly2008
                      I forgot to mention that you can also export a half hull from Delftship.
                        Like the firsthalf above?
                        http://forums.sketchucation.com/download/file.php?id=49408&t=1
                          charly2008
                          Half hull component
                            Gianluca
                            How can i export the hull on SketchUp?
                            • X Offline
                              xrok1
                              export DXF, import DXF. 😉
                                Gianluca
                                Thank you! 😉
                                  Gianluca
                                  How can i draw the hull of my ship under this face with DelftShip?
                                  http://i49.tinypic.com/rcob9j.png
                                    charly2008
                                    Hi Gianluca,
                                    the best workflow is to import your shape as a background image in the plan view. There are many tutorials in th net see the links below.
                                    http://www.google.de/url?sa=t&source=web&ct=res&cd=3&ved=0CCAQFjAC&url=http%3A%2F%2Fwww.boatdesign.net%2Fforums%2Fattachments%2Fdesign-software%2F33338d1248034181-step-step-design-your-boat-tutorial01.pdf&rct=j&q=delftship+tutorial&ei=A4wgTP-tDZyJONvj9B4&usg=AFQjCNFixMtN16ezIqLrCdCMdBpedUmw0Q.
                                    Delftship tutorial
                                    Delftship tutorial
                                    (www.modelboatmayhem.co.uk)
                                    Just a moment...
                                    (forum.woodenboat.com)
                                      Gianluca
                                      Thank you Charlie2008! 😉
                                        Soap Skin and Bubble can make also half Hull 😉
                                        FOr the moment it's always free 😉
                                          Gianluca
                                          Yes, i have it! 😉
                                          Thanks for reply Pilou! 😉
                                            charly2008
                                            Here again the workflow:
                                            1. Export the model (in this the plan view, you can additional export the profile view) as image with dimensions from sketchup.
                                            2. Import the Image to Delftship. Place it at point of origin and then scale the image.
                                            3. Model the hull
                                            4. Export model as dxf and import into Sketchup
