    Draw infinite lines?
    18 Posts 4 Posters 1.9k Views 4 Watching
    • fredo6F
      There is no way to do it directly (you would have to make advanced computation about the vie camera to make sure that the line looks 'infinite', with update for any change of view and type of perspective. So, unless you really want the line to appear as embedded within the model (i.e. being hidden by objects of the mdoel when behind, etc...), you should use view.draw2d instead with clipping on the viewport boundaries.
        Or temporarily set the model.bounds +1000m and then make the 'line' ~ that long, so you still see it - it doesn't really need to be 'infinite' - does it πŸ˜•
          I just want to draw these infinite guide lines that SU's tools uses some times, like the rotation or protractor tool does.
          So I'm trying to find a way for it to be in 3D so one can see the guidelines in 3d space. Otherwise I'd just use the draw2d methods.
          • fredo6F
            Have a look at what is done in FredoScale protractor tool (for instance for the rotation tool). If this is what you need I can tell you then where is the corresponding code.
              The Rotation (Free) tool?
              Looks to be drawn in the view plane, 2d. ?
              I see you've also remade SU's protractor, I guess this gizmo is something that could be make into a reusable code snippet. I've just reinvented it myself. πŸ˜’
              • fredo6F
                Yes it is 2D (but in the plan of rotation), so the direction is 3D
                I am afraid many scripters will end up rewriting their own ruby code for mimiquing the standrad SU tools (unless SU publishes some classes).
                fredo
                  If you want 3D guides why not just use 3D guides [clines] made within the draw command and then erase them when they are no longer needed or on deactivate ? I use this in 2D tools with cpoints etc to let you snap to them on a line you have 'drawn' in temporary graphics but is not really there otherwise; they are collected into an array of entities and they are erased afterwards πŸ˜•
                    I want them for illustrative purposes, but I don't want my inputpoints to snap to them.
                    Too bad the API lacks this feature.
                    • fredo6F
                      @thomthom said:
                      Given a 3d vector, does anyone have any idea of drawing an infinite line using the view.draw* methods?
                      Tom,
                      Attached is a small code snippet (extracted and adapted from LibFredo6) which computes the 2D line simulating an infinite line in 3D.
                      Say you have 2 points in 3D space: pt1_3d and pt2_3d.
                      Based on the current view, you can compute the line in 2D representation
                      pt1, pt2 = infinite_line(view, pt1_3d, pt2_3d)
                      Then you just have to draw it
                      view.draw2d GL_LINE_STRIP, pt1, pt2
                      Of course, because the view can be altered by zooming and orbiting, you need
                      • either to do the computation within the draw method of the Tool
                      • compute it once and then only on each resume events
                      Not a script - only code inside
                      • Dan RathbunD
                        Dan Rathbun
                        You have the first point ( pt1 ) a Geom::Point3d object.
                        How about using Geom::Point3d.offset like so: (not tested)
                        vec is some vector you set
                        len = model.bounds.diagonal * 2
                        pt2 = pt1.offset( vec, len )
                        xytl=view.corner(0) # topleft  an [x,y] Array
                        xybr=view.corner(3) # botright an [x,y] Array
                        xyp2=view.screen_coords(pt2) # a Point3d (ignore z value)
                        until not(xyp2.x.between?(xytl.x,xybr.x) and xyp2.y.between?(xytl.y,xybr.y))
                          len += len  # double the length
                          pt2 = pt1.offset( vec, len ) # get a new pt2
                          xyp2=view.screen_coords(pt2) # get it's new coords
                        view.draw_polyline( pt1, pt2 )
                          Same goes for my example. Recompute pt2 onResume.
                        I'm not here much anymore.
                          What if you are able to calculate the vanishing point?
                          • fredo6F
                            This is a good idea.
                            This will allow also to use view.draw_line method and have the line be fully embedded in the 3D model (i.e. not visible when it crosses solids).
                            Of course, one need to compute this vanishing point based on the perspective view. In principle, offsetting by a distance of 1 million miles should make it!
                              Might still be an issue, you need to use the Tool's getExtent method to return a Boundingbox big enough. But if you do that you cause the OpenGL clipping.
                              I've been trying to search for how it's generally done, infinite lines, and I think that they are drawn with special instructions in order to create such projection...
                              Not sure though... but this infinite line thing is bugging me!
                                And... what if the view is parallel...?
                                • fredo6F
                                  I mean if you have a point and a direction, I guess that by offsetting the point by a huge distance will make the line looks infinite. This should be independent of the view.
                                  PS: do you wish to create a physical line or just draw it in a view?
                                    Two 'infinite' parallel lines that are in fact only a few km long will appear to have a common end-point in the far distance... simply because both of their end-points will use the same screen-pixel - so they'll look like they spring from a common point BUT are actually parallel and will not.
                                    Isn't it pointless to worry about this infinity-ness, provided that they 'appear' infinitely long ?
                                      Yes, that is what I try to do. Draw a line that appear to be infinite - that i ends in the SU horizon. Like the protractor tool does when you rotate. Or like an Guide Line does.
                                      I was thinking that if you could calculate where the projection meet, you could then use that as a measurement of how long the line should be, provided you could work out what the screen point represented in world coordinates.
