    [Plugin] jf_get_dimensions.rb
    61 Posts 21 Posters 72.7k Views 21 Watching
      Jim
      This simple plugin displays the dimensions (width, length, depth) of a selected Group or Instance.
      Unlike the BoundingBox dimensions, the dimensions are correct even when the object is rotated and scaled. Units are displayed in the model units.
      (Width, Height, Depth) correspond to the object's (X, Y, Z) dimensions.
      Menu: Plugins / jf Get Dimensions
      reference: http://forums.sketchucation.com/viewtopic.php?f=323&t=28842
      version 1.1 2014-04-02
        Jim
        I like what this does, but menus are so clunky. Can anyone envision an interface that is fast yet non-intrusive?
        What about a small, button-size webdialog that activates on an onMouseOver event? No clicking, just activates as you pass your mouse over it.
        Or maybe on the other end of the spectrum, a complete alternative to the Entity Info window, but with much more information?
          Entity Into window with collapsible sections of data.
            Jim, I didn't know I needed this plugin but it is very useful. Although I assigned a keyboard shortcut to it, I like your idea of mouseover so you don't have to reactivate the tool for each component.
              Yesterday I hacked the Query tools that comes with SU to display the .bounds dimension for the entity you hover over by request from someone at my office.
              Both a query tool that display info on screen and an enhanced Entity Info window has its uses.
              What if you have this Entity Info++ window, where at each section you also have a checkbox. That checkbox controls what info you get on screen with Query Tool++.
              ❓ πŸ’­
              TT Hack
                dedmin
                This is the most used plugin in my toolbox - assigned shortcut "N" to it! Thanks again Jim for improving it!! πŸŽ‰ πŸŽ‰
                  dedmin
                  ❓ πŸ’­
                  The same problem with components not aligned to the world axes as the old Get Dimensions plugin:
                    ah! oops!
                      Ben Ritter
                      Jim, thank you for sharing.
                        dedmin
                          In SketchUp when it rounds of a value it prefix it with a tilde ~.
                          If the lenght is 10.522221 and your model units are set to display only two decimals, SU will display that as "~ 10.52"
                            dedmin
                            The problem is that the plugin can't recognize SketchUP's circles - it shows different sizes for x and y. Here is the old plugin:
                              Ben Ritter
                              Jim, thank you.
                                Jim
                                @ben ritter said:
                                Jim, thank you.
                                You're welcome.
                                This knows nothing of circles, or any other actual geometry. It only reports the BoundingBox dimensions adjusted for rotation.
                                Dave, that is the only way I can reproduce the results. And it makes sense (to me, anyway) that an odd-sided circle has differing dimensions due to the segments being non-symmetrical.
                                  I get the same results as dedmin if I drag out the radius of the circle off axis or if I use an odd number (25) of sides for the circle instead of an even number. On the other hand, with the radius dragged out on axis and an even number of sides, I get the same value for x and y even with Precision set to 0.000001mm it is the same value. Those results are all understandable since the plugin is reporting the size of the bounding box.
                                    dedmin
                                    I see. Thanks for the explanation. This SketchUp "geometry" is becoming a big problem for me. To bad, but I have to move to other more precise software.
                                      Sounds like you might need a NURBS modeller - one that understand circles.
                                      Bonzai or Rhino comes to mind.
                                        dedmin
                                        Rhino is my choice - the new version 5 is very promising. Gonna miss SketchUp's components, FredoScale and the community!
                                          dedmin
                                          Here is a new version that displays the dimensions on the status bar
                                          Made by a russian guy called 'newsposting'
                                          GetDimensions.rb
                                          • mitcorbM Offline
                                            mitcorb
                                            Hi, dedmin:
                                            Can you point to the source of the Russian guy's plugin?
                                            • 1 / 4
