    [REQ] Select all connected faces with same orientation
    11 Posts 4 Posters 1.6k Views 4 Watching
      Selection toys
      Right Click -> Select -> Connected Coplanar Faces
        hmmm... you didn't mean for coplanar faces, did you?
        • PixeroP Offline
          Pixero
          Not coplanar. I mean connected faces that are the same, frontside or backside.
          So the tool would select all connected faces that have the "same"* normal direction as the first selected face.
          • Same, meaning either the font or back side.
          Sorry for beeing a bit vague. I hope it's a bit clearer now.
            Can one assume that each edge only connects to max 2 faces?
              This one liner will do it, but you might want to check that f is a face?
              m=Sketchup.active_model;s=m.selection;f=s[0];a=[f];f.all_connected.each{|e|a<<e if e.class==Sketchup;;Face and e.normal==f.normal};s.clear;s.add(a)
                Is it possible to select all connected faces with same orientation?
                or not connected will be very fine โ˜€
                Asked for a while, but seems that is not very easy to make!
                All existing plugs give partial result ๐Ÿ˜ฎ
                  For all faces with same normal try this (again you can add a check etc that f is a face)
                  m=Sketchup.active_model;s=m.selection;f=s[0];a=[f];m.active_entities.to_a.each{|e|a<<e if e.class==Sketchup;;Face and e.normal==f.normal};s.clear;s.add(a)
                  ๐Ÿ˜‰
                    My impression was a selection tools more in the way that Orient Faces works out how faces in a surface is oriented. (Sans the actual orienting.)
                      If you want to check/match face 'orientations' rather than the faces' 'normals' there are always the methods used in my orient_faces.rb - that mimics the built in 'orient' other faces tool for a face. The test to reverse faces uses the edge-reversed-in-face etc, that returns a certain way if the pairs of faces are oriented [in]consistently... It only works with two faces per edge as three means one is always 'wrong'... ๐Ÿ˜’
                      Here is the fileorient_faces.rb
                      • PixeroP Offline
                        Pixero
                        Yes that was what I was thinking also.
