    Getting Started
    75 Posts 45 Posters 192.7k Views 45 Watching
    • Chris FullmerC
      Hi disturbed. We have it set that after 2 approved posts you are a full fledged memeber of the community. I guess that until that time you are not allowed to download attachments? I didn't realize that. That is unfortunate I think. So one more post from you and you should be all set,
      • GaieusG
        Guys I do not understand this as "Newly registered members" are supposed to access all attachments. I did double check all these permissions (and know that some people can download these plugins with no problem at all).
          disturbed13
          hmmmmm interesting
          well this should take care of it
          • Chris FullmerC
            Intersting, I had also thought it was set so that any registered member could download. At any rate, he's reached the 2 post threshold so he is now set either way.
            • T
              talimgw
              thanks for the tips!
              • GaieusG
                A list of GIF images we use on the Tutorial pages. Coen made them a while back and I thought sometimes they can be handy to insert into help posts especially here, in the newbie forum.
                http://www.sketchucation.com/wp-content/uploads/instruct/arc.gif
                Arc
                http://www.sketchucation.com/wp-content/uploads/instruct/axes.gif
                Axes
                http://www.sketchucation.com/wp-content/uploads/instruct/circle.gif
                Circle
                http://www.sketchucation.com/wp-content/uploads/instruct/dimension.gif
                Dimension
                http://www.sketchucation.com/wp-content/uploads/instruct/eraser.gif
                Eraser
                http://www.sketchucation.com/wp-content/uploads/instruct/fieldofview.gif
                Field Of View (FOV)
                http://www.sketchucation.com/wp-content/uploads/instruct/followme.gif
                Follow me
                http://www.sketchucation.com/wp-content/uploads/instruct/line.gif
                Line
                http://www.sketchucation.com/wp-content/uploads/instruct/move.gif
                Move
                http://www.sketchucation.com/wp-content/uploads/instruct/offset.gif
                Offset
                http://www.sketchucation.com/wp-content/uploads/instruct/orbit.gif
                Orbit
                http://www.sketchucation.com/wp-content/uploads/instruct/paintbucket.gif
                Paint bucket
                http://www.sketchucation.com/wp-content/uploads/instruct/pan.gif
                Pan
                http://www.sketchucation.com/wp-content/uploads/instruct/polygon.gif
                Polygon
                http://www.sketchucation.com/wp-content/uploads/instruct/protractor.gif
                Protractor
                [img:zpan7hbs]http://www.sketchucation.com/wp-content/uploads/instruct/pushpull.gif[/img:zpan7hbs] PushPull
                [img:zpan7hbs]http://www.sketchucation.com/wp-content/uploads/instruct/rectangle.gif[/img:zpan7hbs] Rectangle
                [img:zpan7hbs]http://www.sketchucation.com/wp-content/uploads/instruct/rotate.gif[/img:zpan7hbs] Rotate
                [img:zpan7hbs]http://www.sketchucation.com/wp-content/uploads/instruct/scale.gif[/img:zpan7hbs] Scale
                [img:zpan7hbs]http://www.sketchucation.com/wp-content/uploads/instruct/section.gif[/img:zpan7hbs] Section
                [img:zpan7hbs]http://www.sketchucation.com/wp-content/uploads/instruct/select.gif[/img:zpan7hbs] Select
                [img:zpan7hbs]http://www.sketchucation.com/wp-content/uploads/instruct/tapemeasure.gif[/img:zpan7hbs] Tape measure
                [img:zpan7hbs]http://www.sketchucation.com/wp-content/uploads/instruct/text.gif[/img:zpan7hbs] Text
                [img:zpan7hbs]http://www.sketchucation.com/wp-content/uploads/instruct/zoom.gif[/img:zpan7hbs] Zoom
                [img:zpan7hbs]http://www.sketchucation.com/wp-content/uploads/instruct/zoomwindow.gif[/img:zpan7hbs] Zoom to selection
                  Jan Steinman
                  @remus said:
                  The exporters are the only difference between the free and pro versions.
                  And the ability to create dynamic components, which alone was reason enough for me to go through the considerable hassle of getting a higher ed license for pro.
                  • GaieusG
                    @jan steinman said:
                    And the ability to create dynamic components...
                    True but Remus wrote that post about half a year before SU 7 (and DC's with it) came out.
                    Anyway, welcome to SCF!
                    • pyrolunaP
                      pyroluna
                      don't forget Layout and Style builder which only come with Pro, and the ability to choose some other (higher) resolution for your JPG-output than "View Size". Does come in handy for printing stuff!
                      • GaieusG
                        Martha, it was only in version 5 when you could only export screen resolution with SU Free. Now (theoretically) you can go up to 9999 pixels (and even higher on the Mac).
                        True however that all the printing (e.g. to scale) havoc can be easily and nicely solved in LO (thus it is in the professional package) although strictly speaking it is not "part" of SU but an additional tool.
                        • pyrolunaP
                          pyroluna
                          Well, I'm certain it was version 6, since I've never used 5, but have had to deal with max resolution for jpgs. But I've been using pro now for a while and must admit I'm not very up-to-date on the limitations of the current free version 😳
                          • GaieusG
                            Well, I used the free 5 then the free 6 for a while and only then went to pro but I remember when first encountering version 7, I first installed the free version just to see what it can do and only then I installed the pro version.
                            Anyway, what can be said is that the two programs are exactly the same and what difference can be found are only done by plugins (DC's are also plugins) and other addons like exporters/importers.
                            This theoretical concept will probably allow the developers a bit bigger freedom as they do not need to maintain two, different versions of the core application itself.
                              sketch12345
                              Hi to all of you guys.
                              I am new here in this site and also newbie in sketchup.
                              Thanks for this site.
                                SketchUpNoobie
                                Hello and welcome to Sketchucation. If you are just learning SketchUp, you've sure come to the right place. These guys and gals are awesome. Feel free to drop ANY questions you have into the newbie forum and get be prepared for a real quick reply. πŸ˜‰ Have fun learning and using Sketchup! πŸ˜„
                                SketchUpNoobie: the complete noob in all things SketchUp.
                                • W
                                  wheeljack
                                  So I'm fairly new to this program and the virtual 3D world in general. I get a little lost when someone explains something and uses one or more words that are specific to the program or 3D programs in general. I know this would be a chore for one person to do but perhaps a thread of such words and their definitions could later be organized alphabetically which can be updated quarterly or something as the thread grows. Just a thought.
                                  • Alan FraserA
                                    Alan Fraser
                                    A Glossary of terms is already well under way on the official site.
                                    http://sites.google.com/site/sagesuwiki/terminology
                                    I hope this helps.
                                    3D Figures
                                    • W
                                      wheeljack
                                      I hope this helps.
                                      thanks a million. πŸ˜‰
                                      • G
                                        greenbelt
                                        Has anyone else found that the audio on the Sketchup for Dummies tutorials is barely audible? Aiden Chopra also mumbles which makes it impossible to understand anything.
                                        Newbie. Planning my dream retirement home!!
                                          I haven't had any problem with the audio on those videos at all. I find Aidan to be very understandable and there's no problem with the volume. Perhaps it's the volume settings on your computer?
                                            DesignChest
                                            I am new to the forum and looking for help and tips from anyone who has the time to show me a few things.
                                            I am currently trying to create a smooth animation and better rendering but also any plug in advice. I have been attacking tutorials like mad but there are parts of my tool pallet that are lacking that I can't get the icons for when I install the plugins. Seeing lots of screen grabs with all sorts of tools I would love to have but don't know what they are!
                                            Hope you can help
                                            http://img823.imageshack.us/img823/2785/953499.png
                                            Uploaded with ImageShack.us
                                            • 2 / 4
