Length line/Edge
hello,
how can i change the length of line/edge by ruby script ?regevz
Apply a scaling transformation to it.
The
edgehas twovertices- its 'ends'.
Found byedge.startandedge.endoredge.vertices[0]andedge.vertices[1].
Let's assume you want to move the edge's end bydist=100.mm
We know the 'line' of the edge fromline=edge.line, whereline[0]==edge.start.positionandvector=line[1]is the line's vector towards its 'end'.
Now work out where the new end would be by using anoffseton a copy of the end-point bydist...
new_end_point = edge.end.position.clone.offset(vector,dist)
So now we have the point where we want the end-vertex to move to.
You have to make atransformationto apply to thatvertex
[ruby:3gl99xg3]tr=Geom::Transformation.new(new_end_point)[/ruby:3gl99xg3]
Now you apply it to thevertex- it's done in a convoluted way for avertexcompared to other '[ruby:3gl99xg3]entities[/ruby:3gl99xg3]'...
If you are working in a group use '[ruby:3gl99xg3]group.entities...[/ruby:3gl99xg3]', but here I assume it's in the model...
[ruby:3gl99xg3]Sketchup.active_mode.active_entities.transform_entities(tr, edge.end)[/ruby:3gl99xg3]
The end-vertex of the edge should now move 100.mm further away from the start-vertex...
If you want to move the start-vertex then use [ruby:3gl99xg3]vector.reverse[/ruby:3gl99xg3] and substitute the start/end vertices.
For other units change the method e.g. [ruby:3gl99xg3]0.1.m[/ruby:3gl99xg3] or with no suffix it's taken as [ruby:3gl99xg3]inches[/ruby:3gl99xg3]...........
TIG, 10x allot for your detailed post.
very useful.regevz
@tig said:
The
[ruby:anqq9m2l]tr=Geom::Transformation.new(new_end_point)[/ruby:anqq9m2l]
Now you apply it to thevertex- it's done in a convoluted way for avertexcompared to other '[ruby:anqq9m2l]entities[/ruby:anqq9m2l]'...
If you are working in a group use '[ruby:anqq9m2l]group.entities...[/ruby:anqq9m2l]', but here I assume it's in the model...
[ruby:anqq9m2l]Sketchup.active_mode.active_entities.transform_entities(tr, edge.end)[/ruby:anqq9m2l]
If you want to move the start-vertex then use [ruby:anqq9m2l]vector.reverse[/ruby:anqq9m2l] and substitute the start/end vertices.
For other units change the method e.g. [ruby:anqq9m2l]0.1.m[/ruby:anqq9m2l] or with no suffix it's taken as [ruby:anqq9m2l]inches[/ruby:anqq9m2l]...........
