    OMG! fur plugin is AMAZING!
    168 Posts 44 Posters 70.3k Views 44 Watching
      Hi Bran,
      "Tune up" the Density and the Max number settings (top two) considerably. The first is set to 200 pieces per 1 m2 (or about 9 square feet) which is obviously too low for a real, dense grass.
      Be carefully however NOT to populate your scene with too many instances as they can (and definitely WILL) slow down SU considerably. Experiment with smaller areas first to see what results you get.
      • massimoM Offline
        massimo Moderator
        Bran, you can also hit the "make fur" button many times on the same surface.
        • FletchF Offline
          Fletch
          @frederik said:
          However, if you're able to save the texture with a transparent background (I.e. as a .png file), it will automatically be made into an alpha-channel... πŸ˜‰
          simply "fix" the buffalo grass component to contain the .png file with the alpha mask already inside it πŸ˜’
          voila... then everything is automatic in Twilight. πŸ˜‰
          oops - thanks dozer, I see you "fixed" it for Twilight. β˜€
          Fletch
          • FrederikF Offline
            Frederik
            Like so many others, I'm having a blast with this new toy...
            I've made some "Make Fur Components" based on some of the models from Solo's garden pack 1, which I highly recommend...
            Some of these components are based on parts of the models (I.e. the ivy is only 3 leaves that have been positioned a little different)...
            This is SO COOL and have opened up for so many new possibilities... πŸ˜„
            Cheers
            Kim Frederik
            • boofredlayB Offline
              boofredlay
              O dear Lord what have I done 😲
              • michaliszissiouM Offline
                michaliszissiou
                Yeah Boofredlay, what have you done? πŸ˜†
                  You'll go blind........
                    joppermann
                    I know you are excited about the plug-in...but jeesh!
                    • F Offline
                      fymoro
                      Wow really cool Jonathan, congrats... πŸ˜‰ I think that the 4min to understand what the f...k is going on, Was the time SU send the information to Vray... πŸ˜•
                      http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                      • holmes1977H Offline
                        holmes1977
                        Arrrrrrrrrrrrr Im so busy at work and all I want to do is play with this pluggin.
                        This is an old scene I did ages ago. Looks alot better with FUR
                        Only PS was the really bad smoke.
                        Rendered in Vray. It took about 4min for Vray to figure out wat the F@#K was going on, then 2mins to render.
                        http://i607.photobucket.com/albums/tt154/holmes1977_album/RUNFAST_PS_02copy-1.jpg
                        Exaggeration makes a dull story better.
                          holmes1977
                          So true Fred. Sorry for the language under huge pressure at work. But no excuse for toilet talk.
                            kwistenbiebel
                            I simply love that last image πŸ˜„. It puts a smile on my face.
                            The fur plugin is great.
                            It is still unbelievable that google didn't make a 64 bit version of sketchup, so we can export higher poly models like these with ease to our render apps.(32 bit limits the RAM usage).
                            It would make life so much easier (fur, trees, etc...)
                            • EarthMoverE Offline
                              EarthMover
                              Had a quick play. Used the fur plugin to distribute a plane with a transparent grass image I made. Worked fairly well. Image attached if anyone else wants to have a go.
                              Content Creator at Skapeup
                              • olisheaO Offline
                                olishea
                                earthmover.....where do you get those trees? looks great and the grass is fantastic, thanks for sharing.
                                holmes thats such a funny scene! they look terrified!
                                I actually used the fur plugin today for some marketing imagery that a housing association asked me to do. This is just a test render to see if they like it....i only let it render for 5 minutes. funny because the houses illustrated are not actually code 6 eco houses πŸ˜† although there are a few on that site. its supposed to look like grass penetrating the tarmac.
                                love this plugin! and the new version has direction.....for wind blown grass/gravity etc.
                                http://i654.photobucket.com/albums/uu269/olishea/4_small.jpg
                                oli
                                  EarthMover
                                  Oli, thanks! The background trees are from you! The other tree is one of the "Smart Trees" from the warehouse.
                                    tallbridgeguy
                                    Pretty cool stuff. I just wanted to add my thanks for the plugin.
                                    I was thinking the plugin has opened the door wider for making ART with su & (insert renderer). Maybe that could be a future challenge. Best abstract image?
                                    thanks for the plugin! And impressive work guys.
                                    http://www.tallbridgeguy.com/wp-content/uploads/2010/05/yellwd3c.jpg
                                    coffee break play.
                                    Nielsen
                                    • olisheaO Offline
                                      olishea
                                      Yeah thats the one I meant! I recognized the background straight away lol πŸ˜†
                                      oli
                                        How come no-one thought of a hedgehog yet?
                                        πŸ˜„
                                        Warehouse model of the hedgehog and of the apple.
                                        πŸ‘
                                        A render...
                                          boofredlay
                                          Looks like a Chia Pet.
                                            Just rendering it in Twilight - man, this is slooow! Probably really heavy and complex geometry (did not use component instances which would probably speed the render up)
                                            πŸ˜•
                                            • 6 / 9
