    [Plugin] Lattice Maker
    149 Posts 69 Posters 374.8k Views 68 Watching
      Maybe some fertilizer necessary! 😆
      • P
        Panga
        Love that furred, latticed fur! 🤣
          dylan
          Thanks Tig.
          http://dmdarchitecture.co.uk/
              rv1974
              must have tool for architects. Thank you Tig!
                Jim
                Thatched roofs are possible now?
                • olisheaO
                  olishea
                  TIG: will it catch on? of course it will!
                  have you seen this building? your plugins+fur will surely facilitate this process.
                  http://www.284brasil.com.br/blog/wp-content/uploads/2010/04/shanghai_expo_pavilion_heatherwick_studio_expo2010-yatzer_3.jpg
                  oli
                    saturne45
                    Great works mister TIG...
                    • david_hD
                      david_h
                      okay . . .this is a keeper! Thanks again!
                      • MALAISEM
                        MALAISE
                        AN another incredible tool. Thx 😍
                          seasdes
                          Hello TIG
                          This is a very nice tool. Thank you.
                          The way it draws lattices at present is that the perimeter part are half the total width of the internal parts. Is there a way to make the external parts the same width as the internal parts (Ala Windowizer). Or, better still provide for user to specify different specific widths.
                          Seasdes
                          Using Sketchup Pro 2019
                            @seasdes said:
                            Hello TIG
                            The way it draws lattices at present is that the perimeter part are half the total width of the internal parts. Is there a way to make the external parts the same width as the internal parts (A la Windowizer). Or, better still provide for user to specify different specific widths.
                            Seasdes
                            No. It's primarily intended to make full lattices, that would then have no perimeter 'edges'...
                            However, you can draw lines around the edges first offset by the frame width like thisCapture.PNG
                              You can also use my alternative if you want a more detailled window 😉
                              Multiple face Offset by Remus is a very usefull plug ☀
                              • H
                                harshal kshatriya
                                hey man.......
                                really cool plugin...!!!
                                I love it...
                                every architect must have it...!!
                                Thanks again.. 👍 👍 👍 😄
                                  AcesHigh
                                  LMAO at the furred latticed fur.
                                  I wonder who will be the first to be a latticed furred latticed fur. 🤣
                                    SU Reviewer
                                    Great Plugin! This is so helpful in creating skylights and greenhouses 💚
                                    A couple of suggestions for future a version. Try to create a button and maybe some more color options for the lattice, even a way to select custom colors/materials. And when creating the pane if it would be possible to add an option for pane thickness.
                                    http://sketchuppluginreviews.com/wp-content/uploads/2010/05/lattice_maker_greenhouse.jpg
                                    Living Einstein's dream through SketchUp.
                                    "Imagination is a preview of life's coming attractions" - Albert Einstein
                                    Joe Simhon ~ SketchUp Plugin Reviews
                                    • broomstickB
                                      broomstick
                                      is this an update of lattice-izer? or a new plugin?
                                        @broomstick said:
                                        is this an update of latticeizer? or a new plugin?
                                        'Lattice Maker' is an 'alternative' to my Latticeizer, based on my tools EEbyRailToLattice's methods - it does everything that that did, whilst outside of a group - its materials are now deliberately 'limited', BUT then they're easily swapped afterwards anyway... it will probably supersede it in time........ 🤓
                                          Regardless a great plugin! Check out my review for the Lattice Maker: http://sketchuppluginreviews.com/2010/05/17/lattice-maker-google-sketchup-plugin-review/
                                          A Toolbar is on the list - as the script's note say - please be patient...
                                          The material options were deliberately 'limited'. My Lattice-izer tool attracted some criticism because the Material list could grow too long and go 'off-screen' if you had loads of Materials loaded into the Model - in these new tools I deliberately limited the materials to just a few. When the group is made IF you have given the frames and panes different Materials then it is little effort to edit the new lattice-group, select a face that's a pane [or a frame] and then right-click to context-menu, Select > 'With same material'... then use the Material Browser > Paint-bucket to apply ANY material you want - either in the Model or a-not-yet-used-external-material globally to those now selected faces. So you can quickly modify any lattice-group's panes and/or frames to ANY material desired - either already-loaded or 'outside' of the Model !
                                          Why do you want 'pane-thickness' ? SUp is "design a modelling tool" - not a full-blown 3D-modeller - adding extra pane-faces just a few mm apart will not normally improve your model but load it with lots of extra [unneeded] geometry ?? If you really, really need then you can always use PushPull on the created pane-faces ??
                                            SU Reviewer
                                            Point taken, I did not notice the toolbar note on the script. But I did figure it would come eventually 😄 Having the option to create the thickness of the pane is just a thought that may be beneficial in certain instances, but I do understand your point on limiting the geometry. And thanks for the tip on creating the custom materials for the lattice.
                                            Again this is a great plugin and thank you for your work!
                                            • 2 / 8
