    [Plugin] Make Fur v.2.1.0(20140323)
    650 Posts 255 Posters 1.2m Views 254 Watching
    • E Offline
      eddy
      cool plugin
      thanks, thanks,thanks. 👍 👍
      @ ++ Eddy
      • mitcorbM Offline
        mitcorb
        tak2hata:
        Thank you for your excellent work on this tool.
        I have a question: I see in the parameters selection box the term Jitter. What factor does this refer to? I am not familiar with this term.
        Thanks,
        mitcorb
        • V Offline
          vizfellas
          thx mate 👍
          STUDO Light+Designers http://www.studo.pl
            cool plug indeed ☀
            http://forums.sketchucation.com/download/file.php?id=47754
              tak2hata
              Hi,mitcorb and paulower.
              "jitter" is condition of difference.
              Decrease value of jitter to 0, then fur are same each other.
              About Error 183... I do not understand this well.
              I think that it is the one that concerns the memory perhaps.
              I examines it a little more.
              by TAK2HATA
              • arqpadaoA Offline
                arqpadao
                Great, feel wonderful. I had long hoped that someone develops it.
                thank you.
                fernando padão
                arquiteto
                porto alegre - brasil
                http://arqpadao.blogspot.com
                  autarchos
                  i call it "fuzzy donut adrift." 🤢
                  • RichardR Offline
                    Richard
                    That's quite a nice image mate! Could have been the top of someone's head too! Or my bum sticking out of the water? Im hairy, well not that hairy but you get the pic!
                    [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                    • EarthMoverE Offline
                      EarthMover
                      Funny Richard, it does look kind of like the top of you head in your photo. 😆
                      Content Creator at Skapeup
                      • halroachH Offline
                        halroach
                        Wonderful Plugin tak! ☀ ☀ ☀
                        When loading or saving a preset it zero's out the position of the plugin window. It would be nice if it didn't jump around like that.
                        (This may have been mentioned somewhere... if it has, forgive me)
                        Cool!
                        FlexTools - Super Quick Windows, Doors, Slats...
                        • W Offline
                          Wacov
                          Amazing plugin, can't believe it's actually possible in SU 😄
                            Does it possible to load our own styles?
                            Solved : 😳
                            Just replace Component instance! 😒
                            Or better load By Component Instance 😳 😳 😳
                            (Components must be first on the model 😉
                              tak2hata
                              Hi,all.
                              I updated make fur plugin.
                              It's version 1.2.
                              Rev : 2010-05-09 -- v1.2
                              refreshing Webdialog method change.(no reopen)
                              assign fur_parameter to current material.
                              add ruby definition for any exporters.
                              --get_furmesh_by_mat( face , mat , ret_furmesh = [] )
                              face:want to make fur on.
                              mat :material with fur_parameter.
                              ret_furmesh:return array.[ [ polygonmesh , uv ], [..] , [..]..]
                              ---polygonmesh:mesh of one fur blade.
                              ---uv : UV position on argumented face where grass has grown.
                              sample code is in end of fur_en_v1_2.rb.
                              thanks.
                              by TAK2HATA
                                Aaron H
                                Thank you SOOO much, this is a great plug in.
                                You might want to update the title of the thread subject to include the revision (1.2) and the date, because I know people are having a lot of fun with this.
                                Thanks again, very nice work.
                                • majidM Offline
                                  majid
                                  this is really great and makes jobs more easy, almost unbelievable, thank you mate, thank you 👍
                                    tak2hata
                                    Hi,Aaron and Gaieus!
                                    I will update the title of thread in the next time.!
                                    Thank you for your helps.
                                    by TAK2HATA
                                      rickgraham
                                      If I can make one suggestion for a future version... can you give an option for either metric or imperial. Us 'Yanks' still use imperial (well I do) 😳
                                      Thanks again for a wonderful plug-in.
                                      Rick
                                      • soloS Offline
                                        So do I, but us Yanks need to get our shit together and conform to the sensible universal system already, it's been far too long with our silly system.
                                        • RichardR Offline
                                          Richard
                                          Thoughts of the rest of the world exactly! Just for the life of me (us) cant see why the USA has held out adopting what is pretty much a world standard and a darn simple one! Things are so simple when divided by ten!
                                            rickgraham
                                            Oh, I agree 100%, but it's going to take more than just a few of us to enact that. Heck, I have hard enough time trying to understand why some of the municipalities we work in make decisions like they do.
                                            This might make a good 'Corner Bar' topic to hash over. ❓
                                            Rick
                                            • 32
                                            • 33
                                            • 5 / 33
