    Search local drive from Component browser?
    20 Posts 5 Posters 1.4k Views 5 Watching
    • jeff hammondJ Offline
      @honoluludesktop said:
      If you do it Jeff's way, you eventually get to search drive or folder, but that is limited to file names, and ascii information stored within the components.
      fwiw, that's pretty much the only way mac users can browse by thumbnails.. (unless the original skps are saved a certain way or a third party app is brought in)
      • honoluludesktopH Offline
        honoluludesktop
        Data base management is difficult whenever the number of stuff you want access to increases. For now, I can't think of anything better then sorted folder and component names (tree_oak_large). Problem is that what ever convention you come up with, eventually need to be changed to accommodate a growing, or changing system. Maybe a plugin to rename and reorder, files and folders, using wild cards, and in batches. Ouch, beyond my capacity to envision.
          d12dozr
          Jeff, I can search visually that way but I was looking for a way to search the filenames...say I have a deck kit (named "Deck Kit") saved in one of my Components subfolders, but I don't remember which one. I want to type in "Deck Kit" in my Component browser and search my PC for it, hopefully that will be faster than browsing thru all my folders...ya dig? πŸ˜„ Am I making sense?
          I have the SKP files named well like honoluludesktop says, and I know I can just search my PC for them thru Windows Explorer, but I am trying to save a step or two.
          http://goo.gl/f7ooYh
            honoluludesktop
            Marcus, unless I misunderstand, or Vista is different from WinXP you can do that now. From SU's menu File > Open > select all files and type in the search file name criteria with wild cards as necessary. Or, right click a folder in SU's "Open" window and search. Or, select "look in" (top of SU's "Open" window), select any icon, my computer, a drive, or folder, right click search all within.
              d12dozr
              Thanks honoluludesktop, Vista must be different than XP because I don't have the option to search from SU's "Open File" window, even if I right-click a folder 😞
                honoluludesktop
                Bummer, another reason not to upgrade my OS. I wounder about Win7. Maybe someone else can tell us. How about it Jeff? I see that you are Win7p
                  Or just any any existing utility: http://www.guyswithtowels.com/dev/apps/f2.html
                    SU's browsers aren't very good at presenting the content.
                    They are slow and the view options are not ideal.
                    Browsing by pure image is not easy as often many components look similar.
                    Browsing by pure text is no good either - you need to read all the text.
                    Best would be to have thumbnails AND text - so you scan visually by what looks to be what you are looking for - and then use the text as aid to determine if you located the correct item.
                      honoluludesktop
                      Thomas, thanks for the link. IMO, one of the best features of OutLook, is categories, and the opportunity to cross file the same document. Ideally a SU browser that easily permits that is a first step to better access of a warehouse of components.
                        ha, yeah.. i see what you're saying now. my bad.
                        nah, i use macs.. 7p is my SU version but osx is my operating system.
                        anyway, back to the original topic.. try searching in the import dialog (File -> Import...)
                        i can search the entire system from there using text without leaving sketchup.
                          Jim
                          I was thinking of this recently. The best I can think of is a combination of hierarchical (folders) organization, and filename and label filters.
                          I see something like vertical (column) layout in Mac's Finder for drilling into folder hierarchy, but there needs to be a text box to filter on the filename. And I find more the 2-3 levels of hierarchy cumbersome. (This is how Finder works, sort of.)
                          Immediate information would include: Thumbnail, file size, file name, and date last modified. Include the ability to sort of these fields.
                          Additionally, add the ability to label files using user-defined taxonomy (web 2.0 tagging,) because not everything fits neatly into a hierarchical structure.
                            jim, mac's finder is a bit more powerful than it might appear. (in fact, i'd argue that searching for anything on a mac is a lot easier/faster than windows)
                            a quick rundown of searching in the finder:
                            depending on your filter selections, you can search things such as a line of code from a ruby file etc..
                            if you save as a smart folder (or create one via- Finder->File->New Smart File) then you will always have quick access to that particular search and the folder is automatically updated as the files on the system change.
                              Jim
                              Thanks Jeff. I just got a second-hand Mac recently and am still learning about it. Finder has everything but SU thumbnails, it seems.
                                d12dozr
                                Thanks for the explanation, Jeff πŸ‘
