    Hardware recommendations
    409 Posts 97 Posters 92.7k Views 97 Watching
      I want my Quadro FX 3500 back.... ๐Ÿ˜ž
      • charly2008C Offline
        charly2008
        finally, my new PC is ready for use. I've installed all the software again. Only with the driver for the Creative Audigy sound card, there are problems. Also, some older programs can't be installed any more. Now I have to try the power the PC brings.
        I have selected the following equipment:
        Processor: Intel Core i7 860
        Motherboard: Gigabyte GA-P55-UD3, Intel P55
        RAM: 8 GB
        Grafics card: XFX GeForce GTS 250 512 MB
        two SATA Harddisk each 350 GB
        OS: Windows 7 64-bit
        The first test with Sketchup delivered the following results:
        Test.SKP
        Test.SKP with shadows
        SU Framerate test
        SU Framerate test with shadows
        • brodieB Offline
          brodie
          Good looking computer and good benchmarks there.
          -Brodie
            dsarchs
            This might be a little late in answering but I'm almost positive you need two of the same card to use cross-fire (eg. (2) 5850 CARDS).
            I'd be wary of spending a bunch of money on a workstation graphics card for SU. The only real difference between "gaming" cards and workstation cards are the drivers and the tech. support. For some programs -- 3d Studio Max, for example, the drivers make a huge difference. I haven't heard that they've been optimized for SU.
            For ATI cards, the DirectX 11 seems to be useless for anything less than a 5850 as the cards aren't powerful enough to compensate for the performance hit from using dx11 instead of dx10. The 5000 series is MUCH more energy efficient but you can get more power/$ from using the 4000 series (not to mention more mature drivers). The 4890 is a very powerful card and can be had for ~$180 or so. That said, the 5850 and 5870 are very nice cards.
            Recently there was an article (http://www.tomshardware.com/reviews/2d-windows-gdi,2539-11.html) about 2d (and 2.5d) graphics where the ATI cards perform VERY poorly (and the NVIDIA cards are not much better). Fixes are supposed to be in the works, but it's still worth knowing.
            NVIDIA cards tend to be more expensive than ATI for comparable power although they are sometimes more stable and you need an NVIDIA card to use CUDA (having the graphics card help with general processing) in programs like Octane Render (which looks like it could be amazing).
            Hopefully some of this is helpful.
            Knowledge is a polite word for dead but not buried imagination.
            -e.e.cummings
            • AnssiA Offline
              Anssi
              @dsarchs said:
              This might be a little late in answering but I'm almost positive you need two of the same card to use cross-fire (eg. (2) 5850 CARDS)...
              ...For ATI cards, the DirectX 11 seems to be useless for anything less than a 5850 as the cards aren't powerful enough to compensate for the performance hit from using dx11 instead of dx10.
              DirectX performance and crossfire and related technologies are totally irrelevant in the case of SketchUp. SU uses OpenGL, not DirectX, and OpenGL does not support the multiple graphics card technologies.
              Anssi
                dsarchs
                I was just responding to an earlier question about whether or not you could use different types of cards for cross-fire/sli.
                As for directx, I was saying that the benefits of directx 11 are useless unless you get the top level of cards. I know that SU doesn't use cross-fire or dx, but presumably the machine will be used for programs other than su. GPGPU rendering/processing is coming soon to say nothing of games ๐Ÿ˜‰
                Besides, if SU is the sole reason for investing in new hardware your money would be better spent on cpu/cooling/ram or something and just getting an 8800gt video card.
                -e.e.cummings
                • Y Offline
                  yukonhoo
                  I haven't read through this entire thread (couldn't do 22 pages!), so I apologize if this has been mentioned already, but I'm looking to get some kind of external storage, or something to back up my system because my computer has been acting up lately.
                  I was wondering if there is a particular storage system/brand/type that is most reliable for long-term storage of sketchup files? and then also a system that is best for accessing files more often?
                  Thanks a lot guys!
                  • brookefoxB Offline
                    brookefox
                    So its been a year and a half or so since the survey got under way? Are the results buried in here somewhere, or buried somewhere somewhere?
                    ~ Brooke
                      Dennis_n
                      hi there,
                      did anyone come across the ATI Radeon HD 3200 on a laptop?
                      also, If I buy a laptop in a store, and prepare a flash card with a viewer and a fat skp file, what is the best SU test I can do to compare available models?
                      • brodieB Offline
                        brodie
                        @dennis_n said:
                        hi there,
                        I ran across a ruby awhile back that allows for a SU benchmark http://forums.sketchucation.com/viewtopic.php?f=15&t=10750#p75785
                        If you continue through the following pages you'll find several benchmark skp files that people posted and subsequent results.
                        Also have a look at http://forums.sketchucation.com/viewtopic.php?f=72&t=20076
                        -Brodie
                          brookefox
                          Uh..., that's a seriously useful re-direct.
                          Thanks.
                          ~ Brooke
                          • brodieB Offline
                            brodie
                            haha, sorry about that first link. I thought it would link directly to my post. The link was supposed to redirect you to the 4th page of this thread where I bring up the Test.time_display ruby ๐Ÿ˜„
                            By the way, it doesn't seem to work unless you capitalize that first "T". In other words, it must be Test.time_display NOT test.time_display
                            -Brodie
                              brookefox
                              I wasn't being sarcastic: I just tried the second, thread, link, which was useful to me.
                              ~ Brooke
                              • keea1111K Offline
                                keea1111
                                HI,
                                I just moved onto a used Mac os x 10.5 DUAL 2 GHz PowerPC G5  8 GB DDR SDRAM.  It has a 128 VRAM ATI RADEON 9600 video card.  I know that is the minimum video card sketch recommends, especially for the PRO version.  I am wondering if I need to bump it up to 512 VRAM.  Will I notice a big difference in this leap, or is it more subtle and unnecessary?  I do quit a bit of design work within SU/LO, so I do want to get set up the best I can within reason.  Does anyone have any insight into this need?  thanks,
                                KEEA
                                • AnssiA Offline
                                  Anssi
                                  Keea,
                                  In real life VRAM is mostly relevant if you have a lot of large textures or multiple large screens. I can run SU quite OK with my old laptop that has Nvidia graphics with 64 Mb VRAM, and my other old computer that has an ATI card with 128 Mb, drives a 1080 x 1920 widescreen display quite well too.
                                  Anssi
                                    beau21
                                    I'm looking to buy a desktop at the end of the summer and was hoping to get some opinions on the model I'm leaning towards..
                                    Specs:
                                    27" iMac
                                    2.8GHz Quad-Core Intel Core i7
                                    8GB 1066MHz DDR3 SDRAM - 4x2GB
                                    1TB Serial ATA Drive
                                    ATI Radeon HD 4850 512MB
                                    What does everyone/anyone think of this configuration? Would that be good for modeling programs such as Sketchup, CAD, and the like.
                                    Any/all opinions welcome.
                                    • brodieB Offline
                                      brodie
                                      Specs:
                                      27" iMac
                                      Nice computer, you'll be in very nice shape. SU only uses one core but in my experience with large hospital models 2.8 GHz will do you just fine and your graphics card should be plenty good. For the rest of your programs which use multiple cores it'll be a very nice setup.
                                      -Brodie
                                        red44
                                        beau21
                                        How did you go with the Imac? Any news? Just ordered one but worried now about the ATI reviews...
                                          red44
                                          Anyone else any ideas on the 4850 ATI card? In the the Imac preferably, but not necessarily...
                                            archtrot
                                            We have been dealing with 80MB models in my office lately.
                                            I'm considering buying a couple of computers with the following spec:
                                            Windows 7 64 bit
                                            AMD Athlon 3.5Ghz dual core processor
                                            8 Gb RAM
                                            PNY Quadro 580 with 512 Mb RAM graphics card
                                            I can get this package built for around $2000.
                                            Can I do any better than this without doubling the cost?
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 20
                                            • 21
                                            • 14 / 21
