    Some Ruby Help
    3 Posts 2 Posters 491 Views 2 Watching
    • K
      ktkoh
      I am trying to set a layer to be visible on one page using the code:
      page = page.set_visibility layer visibility
      I have put this code in the ruby console and it runs without error but the layer is not visible on the page as I expected.
      model = Sketchup.active_model
      entities = model.entities
      selection = model.selection
      layers = model.layers
      pages = model.pages
      page = pages["Blank Page"]
      if (page)
      UI.messagebox page
      layername = "A01-Test"
      page = page.set_visibility ["A01-Test"], [true]
      else
      UI.messagebox "Failure"
      Would someone help point out the error in my code?
      Keith
        I have taken the liberty of putting your post's code inside [Code]-braces...
        Assuming you have a page called "Blank Page" and a layer called "A01-Test" then the page set_visibility method takes a 'layer' (NOT a layer name) and a 'boolean' i.e. true or false (NOT an array), so just recast it as follows...
        page.set_visibility(layers["A01-Test"],true)
        I see no need to set the result to anything unless you want to test if it's done it - the method returns the page if successful and nil if failed...
        It should now work... ❓
        • K
          ktkoh
          TIG thanks that worked like I needed it to. Next time I'll remember to add the code brackets. I am in the process of adding features to my makepart ruby and as someone wrote the monkey see monkey do coding only goes so far.
          Keith
