    Car renders,WIPs&videos
    551 Posts 63 Posters 245.5k Views 63 Watching
      d12dozr
      Thanks Eli, how do you get the ground that the car sits on to match/blend so well with the backplate? Is that setup in Sketchup or in Hypershot?
      http://goo.gl/f7ooYh
      • ely862meE
        ely862me
        when i say backplate means all the image u see is one picture..just the model and the shadow is virtual(and i am rotating and positioning the car to look like it s from there--at least i try πŸ˜„ ); the hdri makes the shadow and the reflections on the car
        Elisei (sketchupper)
        Come and See EliseiDesign
          ashraf
          For preview what you can do, is to change the render settings
          Select a small width and height for the output image; click render to preview and to know the location of the car. I agree that this is a workaround.
          Next version should allow you to see the HDR and the back plate without the need to make a quick render.
          Regarding the car you are right, I just asked the person who created it, I was under the impression it was a sketchup model but it is not.
          So here is a sketchup car rendered using SimLab Composer
            d12dozr
            Thanks for the explanation, Eli πŸ€“
            • ely862meE
              ely862me
              Some more shots with hypershot πŸ˜„
              • soloS
                Ely, that last one looks friggin awesome.
                • ely862meE
                  ely862me
                  Thanks Pete! I think that one is the best of all my renders ..
                  • G
                    GoldenFrog
                    I love the last one. But the second one had the trees with sunlight on them (I assume) but it rather looked like an explosion. πŸ˜†
                    Oh, and could you plz put door handles?
                    Remember, great minds think alike, and fools never differ.
                    • G
                      GoldenFrog
                      Oh! Do excuse me, you DID put door handles.
                      • stefanqS
                        stefanq
                        Eli, fantastic set of renderings! Stick with hypershot bro!
                        Cheers,
                        Stefan
                        • Roguer1R
                          Roguer1
                          Wow, the last 2 renders on the last page look really good!
                          Find all my models on the 3D Warehouse
                          • ely862meE
                            ely862me
                            Heh! Thank you guys Well ,yeah , hypershot seems very easy to use!!
                            A wheel.(rim inspired from Fireblade Concept car http://www.egmcartech.com/wp-content/uploads/2008/03/2008_fireblade_concept_noah_images_3.jpg ).
                            The lateral of the tire is bumped in hypershot πŸ˜„ . It looks a bit low poly but when it ll be on the car u wont see that anymore.
                            • G
                              GoldenFrog
                              Very nice, but not the nicest of your renders. What method do you use to make cars?
                              • ely862meE
                                ely862me
                                I'm sorry ,but,haven't u seen this thread ..it's all I know about making cars:pictures,videos,links,notes,answers and additional comments..now,how can u ask what method I use? 😐
                                • G
                                  GoldenFrog
                                  No, I only recently started following it. What I meant was, How do you make the 350Z? I thought--Correct me if I'm wrong--your method couldnt be used to make real cars from blueprints.
                                  Are you using another method for the 350Z, or can your normal method be used for real cars?
                                  • ely862meE
                                    ely862me
                                    It's all about moving edges/lines and for blueprints using the parallel view.
                                    If u do know the software, there shouldn't be such question like ''What method do u use?''! U simply do it the way u like or seems easier for you.
                                    Have a nice day!
                                    • G
                                      GoldenFrog
                                      Oh, Ok. Thanks.
                                      I'll give it a try.
                                      PS I have watched your video tutorial. I have to say, it's like magic watching you work, even though I dont agree with your designs. β˜€
                                      • G
                                        GoldenFrog
                                        I'll take you up on that.
                                        Starting on it right now.
                                        • ely862meE
                                          ely862me
                                          It's been some time,since i've played a bit in Sketchup πŸ˜’ .. anyway,just want to say i' ve been featured with one of my renders on a site,check it out here http://digitalartsecrets.com/2010/05/15/17-striking-car-renderings-that-will-blow-your-mind-away/
                                          πŸ˜„ πŸ˜„
                                          Thank you!
                                          • G
                                            GoldenFrog
                                            Good for you Ely! You're in there along with Marian.
                                            "...Will blow your mind away" I can see why your render was in there. πŸ˜„
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 27
                                            • 28
                                            • 22 / 28
