    Car renders,WIPs&videos
    551 Posts 63 Posters 245.5k Views 63 Watching
      d12dozr
      Eli,
      Those renders are fantastic! Good job πŸ‘
      Are the backgrounds all HDRs?
      http://goo.gl/f7ooYh
        d12dozr
        Thanks Eli, how do you get the ground that the car sits on to match/blend so well with the backplate? Is that setup in Sketchup or in Hypershot?
        • ely862meE
          ely862me
          when i say backplate means all the image u see is one picture..just the model and the shadow is virtual(and i am rotating and positioning the car to look like it s from there--at least i try πŸ˜„ ); the hdri makes the shadow and the reflections on the car
          Elisei (sketchupper)
          Come and See EliseiDesign
            ashraf
            For preview what you can do, is to change the render settings
            Select a small width and height for the output image; click render to preview and to know the location of the car. I agree that this is a workaround.
            Next version should allow you to see the HDR and the back plate without the need to make a quick render.
            Regarding the car you are right, I just asked the person who created it, I was under the impression it was a sketchup model but it is not.
            So here is a sketchup car rendered using SimLab Composer
              d12dozr
              Thanks for the explanation, Eli πŸ€“
              • ely862meE
                ely862me
                Some more shots with hypershot πŸ˜„
                • soloS
                  Ely, that last one looks friggin awesome.
                  • ely862meE
                    ely862me
                    Thanks Pete! I think that one is the best of all my renders ..
                    • G
                      GoldenFrog
                      I love the last one. But the second one had the trees with sunlight on them (I assume) but it rather looked like an explosion. πŸ˜†
                      Oh, and could you plz put door handles?
                      Remember, great minds think alike, and fools never differ.
                      • G
                        GoldenFrog
                        Oh! Do excuse me, you DID put door handles.
                        • stefanqS
                          stefanq
                          Eli, fantastic set of renderings! Stick with hypershot bro!
                          Cheers,
                          Stefan
                          • Roguer1R
                            Roguer1
                            Wow, the last 2 renders on the last page look really good!
                            Find all my models on the 3D Warehouse
                            • ely862meE
                              ely862me
                              Heh! Thank you guys Well ,yeah , hypershot seems very easy to use!!
                              A wheel.(rim inspired from Fireblade Concept car http://www.egmcartech.com/wp-content/uploads/2008/03/2008_fireblade_concept_noah_images_3.jpg ).
                              The lateral of the tire is bumped in hypershot πŸ˜„ . It looks a bit low poly but when it ll be on the car u wont see that anymore.
                              • G
                                GoldenFrog
                                Very nice, but not the nicest of your renders. What method do you use to make cars?
                                • ely862meE
                                  ely862me
                                  I'm sorry ,but,haven't u seen this thread ..it's all I know about making cars:pictures,videos,links,notes,answers and additional comments..now,how can u ask what method I use? 😐
                                  • G
                                    GoldenFrog
                                    No, I only recently started following it. What I meant was, How do you make the 350Z? I thought--Correct me if I'm wrong--your method couldnt be used to make real cars from blueprints.
                                    Are you using another method for the 350Z, or can your normal method be used for real cars?
                                    • ely862meE
                                      ely862me
                                      It's all about moving edges/lines and for blueprints using the parallel view.
                                      If u do know the software, there shouldn't be such question like ''What method do u use?''! U simply do it the way u like or seems easier for you.
                                      Have a nice day!
                                      • G
                                        GoldenFrog
                                        Oh, Ok. Thanks.
                                        I'll give it a try.
                                        PS I have watched your video tutorial. I have to say, it's like magic watching you work, even though I dont agree with your designs. β˜€
                                        • G
                                          GoldenFrog
                                          I'll take you up on that.
                                          Starting on it right now.
                                          • ely862meE
                                            ely862me
                                            It's been some time,since i've played a bit in Sketchup πŸ˜’ .. anyway,just want to say i' ve been featured with one of my renders on a site,check it out here http://digitalartsecrets.com/2010/05/15/17-striking-car-renderings-that-will-blow-your-mind-away/
                                            πŸ˜„ πŸ˜„
                                            Thank you!
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 27
                                            • 28
                                            • 22 / 28
