    Car renders,WIPs&videos
    551 Posts 63 Posters 245.5k Views 63 Watching
    • G
      GoldenFrog
      Scott
      I had no idea. Wierd, because I downloaded the trial version of hypershot rather recently.
      Say, could 'ya check this out? http://sketchup.google.com/3dwarehouse/details?mid=d33cda09d7df70dc25ff9d2d1e4772c3
      Remember, it's a WIP. Thanks. πŸ˜„
      Ely: That widebody kit makes it look really great, but I think you should add some door handles... πŸ˜‰
      Remember, great minds think alike, and fools never differ.
        ashraf
        Hello,
        Here is a Car rendered using SimLab Composer 2.0
        I thought SketchUp community will like buildings more.
        But who doesn't like CARS ? πŸ’š
        • GaieusG
          Well, I don't have a car (and I could not even turn into our narrow street with such a car either)
          πŸ˜„
          But the render definitely looks cool! I only tried it on architectural models. After I collect and "organise" my "experiences", I would like to ask some questions, too.
            d12dozr
            Eli,
            Those renders are fantastic! Good job πŸ‘
            Are the backgrounds all HDRs?
            http://goo.gl/f7ooYh
              d12dozr
              Thanks Eli, how do you get the ground that the car sits on to match/blend so well with the backplate? Is that setup in Sketchup or in Hypershot?
              • ely862meE
                ely862me
                when i say backplate means all the image u see is one picture..just the model and the shadow is virtual(and i am rotating and positioning the car to look like it s from there--at least i try πŸ˜„ ); the hdri makes the shadow and the reflections on the car
                Elisei (sketchupper)
                Come and See EliseiDesign
                  ashraf
                  For preview what you can do, is to change the render settings
                  Select a small width and height for the output image; click render to preview and to know the location of the car. I agree that this is a workaround.
                  Next version should allow you to see the HDR and the back plate without the need to make a quick render.
                  Regarding the car you are right, I just asked the person who created it, I was under the impression it was a sketchup model but it is not.
                  So here is a sketchup car rendered using SimLab Composer
                    d12dozr
                    Thanks for the explanation, Eli πŸ€“
                    • ely862meE
                      ely862me
                      Some more shots with hypershot πŸ˜„
                      • soloS
                        Ely, that last one looks friggin awesome.
                        • ely862meE
                          ely862me
                          Thanks Pete! I think that one is the best of all my renders ..
                          • G
                            GoldenFrog
                            I love the last one. But the second one had the trees with sunlight on them (I assume) but it rather looked like an explosion. πŸ˜†
                            Oh, and could you plz put door handles?
                            • G
                              GoldenFrog
                              Oh! Do excuse me, you DID put door handles.
                              • stefanqS
                                stefanq
                                Eli, fantastic set of renderings! Stick with hypershot bro!
                                Cheers,
                                Stefan
                                • Roguer1R
                                  Roguer1
                                  Wow, the last 2 renders on the last page look really good!
                                  Find all my models on the 3D Warehouse
                                  • ely862meE
                                    ely862me
                                    Heh! Thank you guys Well ,yeah , hypershot seems very easy to use!!
                                    A wheel.(rim inspired from Fireblade Concept car http://www.egmcartech.com/wp-content/uploads/2008/03/2008_fireblade_concept_noah_images_3.jpg ).
                                    The lateral of the tire is bumped in hypershot πŸ˜„ . It looks a bit low poly but when it ll be on the car u wont see that anymore.
                                    • G
                                      GoldenFrog
                                      Very nice, but not the nicest of your renders. What method do you use to make cars?
                                      • ely862meE
                                        ely862me
                                        I'm sorry ,but,haven't u seen this thread ..it's all I know about making cars:pictures,videos,links,notes,answers and additional comments..now,how can u ask what method I use? 😐
                                        • G
                                          GoldenFrog
                                          No, I only recently started following it. What I meant was, How do you make the 350Z? I thought--Correct me if I'm wrong--your method couldnt be used to make real cars from blueprints.
                                          Are you using another method for the 350Z, or can your normal method be used for real cars?
                                          • ely862meE
                                            ely862me
                                            It's all about moving edges/lines and for blueprints using the parallel view.
                                            If u do know the software, there shouldn't be such question like ''What method do u use?''! U simply do it the way u like or seems easier for you.
                                            Have a nice day!
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 27
                                            • 28
                                            • 22 / 28
