    [Plugin] Extrude Edges by Rails by Face
    82 Posts 25 Posters 229.8k Views 25 Watching
      The "profile's" face must be flat facing up [or down] in the Z [blue] axis.
      Try again with that... ❓
        sepo
        😳 yes ...it works now....after reading in detail....
          monkeybss
          But not for me! I've tried all possibilities and the Extrude Edges by Face doesn't work! Is there some other plugin that interferes ?
            None that I know of...
            Are you completely sure you are following the instructions: you do have have curve 'paths' ready and a single flat face selected etc ?
            Do you get any error messages in the Ruby Console when trying to use the tool[s] ?
            EEbyFace needs some preselected edges/curves as paths and a preselected flat face.
            EEbyRailsByFace needs 2/3/4 curves and a face - you preselect the face then choose the four curves to form the 'mesg' ribs - as profile, rail1, rail2 [can be 'rail1' again] and melding_profile [can be 'profile' again] (that's what I said, "...2/3/4 curves..."). The curves should have a modest number of segments and work best with the same or multiples of segments in the profiles/rails - although uneven segmentation will work, uneven 'meshes' can result as the unevenness is ironed out...
              DIEGO-RODRIGUEZ
              Tig.
              a query.
              Why? When the Rails have different number of segments in the rail less divisive segments of different lengths
              could divide the rail in lengths equal?
              [flash=853,505:2alsp9zu]http://www.youtube.com/v/NzdgTrjqodg&fs=1[/flash:2alsp9zu]
                Because rails are curves and these have segments if you give them the same number of segments then they are an even mesh, but if you don't the script tries to even out the mesh as much as possible: so 12+12 is fine [12 ribs], but 12+13 means that we need to squeeze an extra one into the 12 set [13 ribs]. We must run from node to node, we can't spring from a random point along a segment ? The sure way to even up unmatched rails would be to multiply the segments together - e.g 12x13=156 ribs - far too many !!!
                  DIEGO-RODRIGUEZ
                  I have tried.
                  and note that using multiples of the number of segments. for example
                  Rails1 12segment and Rails2 24segmen
                  Rails1 12segment and Rails2 36segmen
                  Rails1 12segment and Rails2 48segmen
                  divisions that are generated in the mesh are equal.
                  however if we use number of segments that are not multiples.
                  divisions that are generated in the mesh are not equal.
                  could enter the number of divisions after selecting the rails and profiles?
                  could preview a mesh phantom, similar to extrudelathe. and create changes in the number of divisions of the rails and profiles?
                  • broomstickB Offline
                    broomstick
                    YOU THE MAN TIG!!
                    First attempt: 30 seconds of calculation!!
                    http://mezzalisca.files.wordpress.com/2010/03/extrude1.jpg
                    Same structure, using extrude edges by rails to do the panes!!
                    http://mezzalisca.files.wordpress.com/2010/03/extrude2.jpg
                    Is it magic? I think it is!!
                    • simon le bonS Offline
                      simon le bon
                      Does somebody have already thought of that fantastic kind of Eebrbf possibilities ?
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TIGeebfbr_028_th.jpg
                      In order to achieve the left figure: -> ->
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TIGeebfbr_029_th.jpg
                      😉 😉 simon
                        And at the end you can now rotate each "lines volumes" between them! 😉
                        For the pleasure of the eyes ☀
                        A geometric study by Cristobal Vila
                          simon le bon
                          Hi Pilou,
                          Isfahan is a pure Gem (as you sometimes like to say) It would deserve a dedicated thread IMO.
                          (I would like to know what softs Cristobal Vila had used.)
                          Can you please explain further. I don't understand what you mean. What you say let me think I have missed an important enhancement.. ❓
                          A remark for TIG:
                          Here and there, the process make Su krashes whith the following message: BUG SPLAT RC _ RESOURCE DLL NOT FOUND
                          Is there some manipulations to avoid?
                          *simon
                            I believe that it's yet exist somewhere in this forum 😉
                            Cristobal uses in general Electric Image! It's a big fan of it 😉
                            You absolutly no missed something 😄
                            Is just that your final example is some "Flat"
                            So if you take each form you can rotate it 😉
                              simon le bon
                              Electric Image Animation System v8.0 EIAS 8 full version $895.00
                              😎 not for me dear Pilou
                              Oh! I see! 😉
                              In my mind that wasn't really an "exemple" to show but a potential to point out. ->How can we obtain else way a regular evolution of a curve from a shape to another in SU without any calculation? I see plenty of possible applications in architecture..
                              -> the other possibility offers a great time saving in building fences, trellis, framework...
                              Here is a quick rather poor exemple
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TigChurch001_th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TigChurch003_th.jpg
                              http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TigChurch004_th.jpg
                              😕 s
                                yes you have also the 2 faces + path who give the evolution of a curve/ surface 😉
                                http://forums.sketchucation.com/download/file.php?id=32785
                                  simon le bon
                                  Kirill 2 faces + path exact, exact 👍
                                    simon le bon
                                    I pursued my idea with : "La jolie petite fontaine"
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/TIGeebfbr_048th.jpg
                                    *s
                                      Morphing_24
                                      Hey TIG
                                      I have just downloaded this plugin and I tried to find an answer here if there is always a default number of ribs . Everytime, I find that there are always 21 ribs and I have no idea how to change it. How can I do it??
                                      thanks
                                        That number depends on the segments in the "rail/profiles's" curve - so add/subtract segments to change that...
                                        Your 'rail/profile' must have 20 segments >> 21 "ends" ???
                                          Morphing_24
                                          thanks, problem solved 😄
                                          But now i have one problem and another question.
                                          I use a macbook pro and this only happens on mac not on the PC generally. The problem is that whenever I try to use the extrude edges by rail by face, and most of the time after I choose profiles and rails it crashes and the crashDialogHeader appears . What do you think it might be??
                                          And the other question is if the number of ribs depend on the segments, I made a curve using the line tool but it looks really edgy, and if I draw a line with the bezier tool, how can I control the number of ribs using this tool and at the same time keeping it smooth?
                                          Thanks in advance
                                            The Bezier tool has an Edit option on its toolbar - so use that to change the number of segments in a curve - it's similar to how you can change the segmentation of an Arc in 'Entity Info'.
                                            • 4 / 5
