    Help with DWG import
    12 Posts 4 Posters 682 Views 4 Watching
    • EdsonE Offline
      Edson
      in general i import dwg files into sketchup without much trouble. in this particular project i am having lots of problems because the files seem to carry 3D aspects with it. could anyone out there check this file in autocad to fix it?
      the original looks like this:dwg_import01.png
      when imported into sketchup it looks like this:dwg_import02.png
      ABR15.dwg.zip
      http://www.mahfuz.arq.br
        Have you checked the origin of the DWG and the insertion points of the blocks? Thinks turn weird when they are too far away from Origin.
          did you mean to attach the dwg file as well?
          • EdsonE Offline
            Edson
            i have had problems before when checking the preserve origin option so this time i did not check it.
            yes, i did. it is up there on the first post now.
            • EdsonE Offline
              Edson
                oops - I did not mean to check the checkbox in the options - I mean inspecting that the coordinates in the DWG was fine.
                  dybi
                  SKP by dybi
                  ABR15_dybi.zip
                  • EdsonE Offline
                    Edson
                    i do not have autocad nor would i know what to do with it. remember, i am a mac user and there is no autocad for mac.
                    • EdsonE Offline
                      Edson
                      @dybi said:
                      SKP by dybi
                      thanks, dybi. do you mind telling me what you did to import it correctly? knowing it i will not bug you again for help...
                        dybi
                        sorry i dont speak english
                        1. explode all blocks
                        2. delete all raster image
                        3. delete all hatch
                        4. purge
                        5. πŸ˜„
                          Ah - you got that DWG from someone else?
                          But is there no freeware that let you open DWGs on mac and do some basic cleaning up?
                          At the office when I import DWGs I always copy just want I want into a fresh DWG and move everything to Origin. Then Purge the DWG. It's the safest method I know. If I don't do that then all sorts of gremlins appear when importing to SU.
                          • honoluludesktopH Offline
                            honoluludesktop
                            Ed, Attached is a dxf (change extention from txt to dxf) that you can import into SU (origin unchecked). It has all the components, and 3d features preserved corectly. You can explode and edit as you see fit.
                            ABR15.txt
