    Landscape Plant Packs - 68 total (update w. alphas)
    68 Posts 49 Posters 59.9k Views 49 Watching
    • W Offline
      wahoowetzel
      Equadorian,
      Are these renderings or image exports from sketchup? I ask because when I try to use them in sketchup I get a square shadow. These work great for renderings, but I'm making an AVI from sketchup and I'd like to have tree shaped shadows, not this:tree test.png
      FYI, I'm still in the process of replacing my place holders, so nevermind the lampshades πŸ˜‰
        Hi Jesse,
        The problem with SU is that although it recognises alpha transparency, its shadows do not support it. So the general workaround is either to roughly cut around the tree shape of turn its shadows off and use a generic, shadow casting face with a transparent image applied on it.
          KXI System
          I got rapidshare to work, now I have and and LOVE IT! 😍
          I really can see myself using these in the future, but one question...
          Why is there logs on fire in the collection?
          Getting the perfect sig is hard...
          Google it!
            SHAHEEN
            thanks for these great images .. they will be useful
            wahoowetzel : u can get rid of this annoying shadow by applying the tree as a material on a plane
            edit the material to add the tree then add the alpha image to the transparency ... that how u can get areal shadow . see the attached images .
            result
            " An eye for an eye only ends up making the whole world blind "
            Gandhi
              Hi Shaheen
              Each file gives the same "not valid" result.
              • EarthMoverE Offline
                EarthMover
                @ondreas said:
                Thank you very, very much EarthMover & Adamfor sharing these great 2D plants...
                One of the best collection I have come across so far !!!
                Thanx again !!!
                You're welcome and you're welcome! πŸ˜„
                Shaheen,
                Better yet, the new update of Vray supports transparency from the image itself with no alpha map needed for .png or .tif. The days of making clipmaps are gone forever....I hope!
                .....and THANKS for sharing the new packs!
                Content Creator at Skapeup
                  SHAHEEN
                  and here is my collection for such images ... i uploaded them at 4shared
                  i hope u would like them
                  Pine trees, Palm trees , deciduous trees 1 +2 & 3
                  http://www.4shared.com/file/198841551/42eaa4ef/_Deciduous_Trees_2.html
                  http://www.4shared.com/file/198888642/7846d8c6/_Deciduous_Trees_3.html
                  http://www.4shared.com/file/198807215/f44f4a6b/Deciduous_Trees_1.html
                  http://www.4shared.com/file/198775624/461327ac/others.html
                  http://www.4shared.com/file/198692635/c1b47306/Palm_Trees.html
                  http://www.4shared.com/file/198747085/22df3159/Pine_Trees.html
                  Gandhi
                    SHAHEEN
                    😐 sorry Gaieus for that
                    there was an error in coping the lik
                    i have fix them
                    thanks again dude , im glad to be here
                    Gandhi
                    • F Offline
                      fabiorossi
                      thank you so much!!!!!!!!!!!!!!!!!!!!
                      my blog
                      http://progettin3d.blogspot.com/
                      • dermotcollD Offline
                        dermotcoll
                        Thanks Earthmover - they look amazing!
                        When you burn your arse - you gotta sit on the blisters!!
                        • kerabeK Offline
                          kerabe
                          Thanks so much for these! I can't wait to try them out.
                          The CH124: If it isn't leaking, you're out of oil...
                            jeabdc
                            I love SketchUp, ThankYou
                            Thailand is Smile Land
                              jeabdc
                              Thank for your Plant Collection
                                SurfingAlien
                                thank you so much EarthMover!
                                great billboards collection (and they work great with the "Always Face Camera" option)
                                as you can see I'm new here, I hope I can give my contribute soon
                                cheers,
                                A
                                • W Offline
                                  whiteninja
                                  thank you so much for all you people who share their beloved plant collections to the community. these really helps πŸ˜† and also thanks for sharing that tip about transparency in vray
                                    alex2402
                                    Hi Adan can you make a tutorial step by step how you make plants like this, and alpha please, i really appreciate your hard work
                                    i wanna create plants like this by my self... thank you in advance ❓ ❓ ❓ ❓
                                    Todos tenemos dones, tu sabes cual es el tuyo?
                                      clucas1975
                                      THANKS EARTH MOVER.
                                      • Z Offline
                                        zbusheha
                                        thanks … absolutely worth it ..
                                        • JpacJ Offline
                                          Jpac
                                          I've added an outline around the Deciduous plants so they cast shadows in SketchUp. They are all 2D Face Me plants now. They are in 3 packs in 3D warehouse. Thanks Earth Mover for posting these!
                                          http://sketchup.google.com/3dwarehouse/details?mid=767b91245cb3c9eddd39584bc969fb96
                                          http://sketchup4sitedesign.wordpress.com/
                                            rickyshuang
                                            very useful stuff, thanks man.
                                            • 4 / 4
