    Landscape Plant Packs - 68 total (update w. alphas)
    68 Posts 49 Posters 64.1k Views 49 Watching
    • W Offline
      wahoowetzel
      possibly post it using humyo?
        @su_rickgraham said:
        Can some kind soul post them somewhere else besides rapidshare? IT has that one blocked! 😞
        Rick
        Adam, Miguel, would you mind if I uploaded them to the Warehouse?
        (With full credits of course and a link to this topic - unless you want to do the hassle)
        • EarthMoverE Offline
          EarthMover
          No Problem Gaieus! Feel free!!
          Content Creator at Skapeup
            Okay, thanks.
            It will take a while as the whole pack is 28Mb so cannot be uploaded in one piece (10 Mb file size limit). I think I will make a "collection" of it then post the link here.
              KXI System
              @gaieus said:
              Okay, thanks.
              Oh, that would be wonderful Gai!
              Getting the perfect sig is hard...
              Google it!
              • F Offline
                fbo_bern
                Hi all
                The collection is great!!
                But if i want to render the plants, that looks bad:
                What is the problem? Options? Or are the plants not make for rendering?
                i use vray for sketchup.
                thanks for help and tips.
                fbo
                  alpro
                  fbo_bern, you need to load the alpha in the transparency slot of the diffuse material for it to render in Vray, at least till the new version is out.
                  Mike
                  • O Offline
                    Ondreas
                    I`ve been out for some time but what I have found here when I came back is just fantastic !!!
                    For example this 2D Landscape Plant Pack created by EarthMover with addition from Adam.
                    Very well done, guys !!! πŸ‘ πŸ‘ πŸ‘
                    Thank you very, very much EarthMover & Adam for sharing these great 2D plants...
                    One of the best collection I have come across so far !!!
                    Thanx again !!!
                    • W Offline
                      wahoowetzel
                      Equadorian,
                      Are these renderings or image exports from sketchup? I ask because when I try to use them in sketchup I get a square shadow. These work great for renderings, but I'm making an AVI from sketchup and I'd like to have tree shaped shadows, not this:tree test.png
                      FYI, I'm still in the process of replacing my place holders, so nevermind the lampshades πŸ˜‰
                        Hi Jesse,
                        The problem with SU is that although it recognises alpha transparency, its shadows do not support it. So the general workaround is either to roughly cut around the tree shape of turn its shadows off and use a generic, shadow casting face with a transparent image applied on it.
                          KXI System
                          I got rapidshare to work, now I have and and LOVE IT! 😍
                          I really can see myself using these in the future, but one question...
                          Why is there logs on fire in the collection?
                          Google it!
                            SHAHEEN
                            thanks for these great images .. they will be useful
                            wahoowetzel : u can get rid of this annoying shadow by applying the tree as a material on a plane
                            edit the material to add the tree then add the alpha image to the transparency ... that how u can get areal shadow . see the attached images .
                            result
                            " An eye for an eye only ends up making the whole world blind "
                            Gandhi
                              Hi Shaheen
                              Each file gives the same "not valid" result.
                                EarthMover
                                @ondreas said:
                                Thank you very, very much EarthMover & Adamfor sharing these great 2D plants...
                                Thanx again !!!
                                You're welcome and you're welcome! πŸ˜„
                                Shaheen,
                                Better yet, the new update of Vray supports transparency from the image itself with no alpha map needed for .png or .tif. The days of making clipmaps are gone forever....I hope!
                                .....and THANKS for sharing the new packs!
                                  SHAHEEN
                                  and here is my collection for such images ... i uploaded them at 4shared
                                  i hope u would like them
                                  Pine trees, Palm trees , deciduous trees 1 +2 & 3
                                  http://www.4shared.com/file/198841551/42eaa4ef/_Deciduous_Trees_2.html
                                  http://www.4shared.com/file/198888642/7846d8c6/_Deciduous_Trees_3.html
                                  http://www.4shared.com/file/198807215/f44f4a6b/Deciduous_Trees_1.html
                                  http://www.4shared.com/file/198775624/461327ac/others.html
                                  http://www.4shared.com/file/198692635/c1b47306/Palm_Trees.html
                                  http://www.4shared.com/file/198747085/22df3159/Pine_Trees.html
                                  Gandhi
                                    SHAHEEN
                                    😐 sorry Gaieus for that
                                    there was an error in coping the lik
                                    i have fix them
                                    thanks again dude , im glad to be here
                                    Gandhi
                                    • F Offline
                                      fabiorossi
                                      thank you so much!!!!!!!!!!!!!!!!!!!!
                                      my blog
                                      http://progettin3d.blogspot.com/
                                      • dermotcollD Offline
                                        dermotcoll
                                        Thanks Earthmover - they look amazing!
                                        When you burn your arse - you gotta sit on the blisters!!
                                        • kerabeK Offline
                                          kerabe
                                          Thanks so much for these! I can't wait to try them out.
                                          The CH124: If it isn't leaking, you're out of oil...
                                            jeabdc
                                            I love SketchUp, ThankYou
                                            Thailand is Smile Land
                                            • 3 / 4
