    Group.copy fails
    11 Posts 4 Posters 600 Views 4 Watching
      Xrok1 has a problem with some of my EEby.. tools where they copy groups and manipulate them.
      At first I thought it was a group make_unique problem... but via PMs and testing of basic code in the Ruby Console we discovered that although group.copy is a listed method you can't set a variable thus: g=group.copy - it simply returns nil. So it's not my scripts, but a glitch with his entire SUp Ruby API. He tried reinstalling SUp... but no joy.
      His current installation is Win7 ultimate64 SUp ver7.1.6860 - which fails: however, his earlier ver7.0.10247 works fine on another machine ??? 😲
      Any ideas out there ???
      πŸ˜• πŸ˜• πŸ˜•
        Jim
        That would be a serious flaw. I've copied Groups in that way many time without trouble (that I know of.)
        First thought is usually "Who's plug-in has changed the default behaviour?" and my reply is "Hopefully, not one of mine!"
          group.copy returns a group in my tests...
          • X Offline
            xrok1
            and the winner is sketchyphysics! πŸ‘Ώ
            i started deleting plugs until etrude worked and its SP. tried on both installs deleting and replacing... i'm not sure which version it is but its from 6/27/2009
            my other install of SU had SP from 3/10/2009 i guess that ones ok πŸ˜†
            • X Offline
              xrok1
              can someone tell me what this is now? got it since i've been screwing around so much. did a reinstall/repair but didn't help.
                So, to recap: it seems that SketchyPhysics in some recent form messes with group.copy ???
                The file c:\windows\SKPLib80U.dll is only referred once on the net within a Trojan test...
                It might be a SP lib ?
                Don't know what it is at all ?
                When do you get the error - when starting SUp ??
                • X Offline
                  xrok1
                  yes it was SP everythng is fine now!!!
                  yes the error was starting SU but i went into preferences and re-enabled all the plugins and it went away. πŸ˜„
                    Jim
                    Searching the code for SketchyPhysics, I don't see it as being the culprit. I've notified Chris to see what he thinks.
                      I've looked too and can't find anything... there is group.definition and various extra group methods, but none that should clash - weird or what ?
                      Xrok1 found that with SP installed, he couldn't get group.copy to work at all it kept returning Nil ! BUT after un-installing SP it all worked OK...
                        Could be an observer interfering?
                        • X Offline
                          xrok1
                          i even reinstalled then uninstalled SP twice to confirm. here is the offending version, i saved a copy for just such skepticism. πŸ˜‰
                          BADSetupSketchyPhysics3x-Jun27.rar
