    3d terrain modelling from spot elevations
    4 Posts 2 Posters 3.1k Views 2 Watching
      cholland
      i am looking to create 3d terrain from spot elevations. I have an
      Autocad file that has spot elevations only. I have imported the file
      into Sketchup and the spot elevations show up as small x's at varying
      heights (as per the elevations). I have tried using the various sandbox tools with no success. Can somebody point me in the right direction?
      many thanks
      CH
      • TIGT Online
        You are part way there.
        You can't make the mesh from 'points' with the Sandbox Tools.
        You need a free third party tool to make the mesh from the 'cloud' of dots.
        First - are these dots guide-points select one and get Entity Info.
        If so then you can use these directly; if not it's probably a component ?
        If it's a component edit it and place a guide-point at its origin.
        Erase any other geometry in the edit, leaving the guide-point behind in the component.
        All of the components should be changed.
        Select them all and Explode them [right-click context-menu item option]
        Now you have guide-points.
        You can select the points and use 'Cloud' Plugin to join these into a mesh...
        Didier Bur's points_cloud_triangulation.rb is available at http://rhin.crai.archi.fr/RubyLibraryDepot/Ruby/EM/points_cloud_triangulation.rb
        and/or cloud6.zip http://rhin.crai.archi.fr/RubyLibraryDepot/Ruby/em_geo_page.htm
        I think you might even be able to use component-markers directly without the guide-point swapping out...
        It might also need delauney2.rb ? Read the file notes...
        These threads also has related stuff http://forums.sketchucation.com/viewtopic.php?f=22&t=4276 and http://forums.sketchucation.com/viewtopic.php?p=122770#p122770 and http://forums.sketchucation.com/viewtopic.php?f=180&t=1537
        πŸ€“
          cholland
          Thanks for the help, I have downloaded the plugins and the following appears under the plugin pull down :import point cloud and then triangulate points. The triangulate points seems to work , but the cloud one wants me to import a file . Any ideas or do I just use the triangulate plugin ?
          Thanks again
          CH
          • TIGT Online
            Just use triangulate... it should give you what you want.
            The cloud tools take data from a file that has a list of 3d points in it in various formats - sometime you get these from a surveyor as well as a dwg - if so you don't need the steps of importing the dwg at all as you can bring the points straight in and make a surface without it...
