    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
      Jim
      Hi Niels,
      A common problem happens when extracting the .zip files. Be sure to keep the folder hierarchy when extracting them.
      Can you post a screen-shot of your Plugins folder?
      Also, please post the error message.
      • GaieusG
        Windows tends to want to create a whole subfolder for the extracted files. I guess what Jim says is NOT to extract them into this additional subfolder but straight under the Plugins folder (keeping any folder hierarchy insidethe zip intact).
        Now the question arises - if this is the problem, SU should not recognise the plugin at all so there should not be any error messages. Did you also install the LibFredo library?
        • bmikeB
          bmike
          Been playing with the 'bend' portion of this plugin.
          Took the straight version and made it into the bent version.
          http://lh5.ggpht.com/_0jkA5M3PGcY/S6fQwKc17WI/AAAAAAAAO5I/6GU41QET1Uk/s800/lakehouse-3-14-10.jpg
          http://lh5.ggpht.com/_0jkA5M3PGcY/S6fQqVX4bPI/AAAAAAAAO5E/5_bPdJRwL34/s800/lakehouse-3-14-10-bend.jpg
          I included the original 2d floorplans embedded in the model.
          Crashed the machine a few times - but I cleaned it up, simplified the original a bit... and it worked.
          I'd love to understand the math on getting the bend to meet a particular arc or radius. I drew a circle of the correct diameter and then eyeballed the model to get it close... which is good enough to see if clients are interested in the massing / concept - and I was even able re-link to LayOut so my views were pretty close and required minimal tweaking...
            and you have 6 curvatures possible from a straight volume πŸ˜‰
              AR-51
              @ar-51 said:
              Hi, I install Libfredo6,RoundCorner and Fredoscal, but I'm unable to use them in SketchUp.
              When I click on Tools>FredoScale noting happens. I also get no response when I click on Window>Libfredo6>Default Parameter.
              Do you have the icons in the Toolbar?
              Otherwise, can you turn the Ruby console on, and then select the menu LibFredo6 Default Parameters.
              Finally, can you check the content of the folders FREDOSCALE_Dir_20, etc... to verify they correspond to the footprint of the doc.
              Thanks Fredo for the response. I don't have the icons in the Toolbar and when I run LibFredo6 Default Parameters, I get this error message:
              Error: #<SyntaxError: (eval):1116: compile error
              (eval):1116: syntax error
              (eval):1116
              I'm going to check the folder again to make sure the files are in other.
              Edit:
              It seems like LibFredo6 is installed, it just wont respond to some commands. I'm able to access (about,documentation and check for update)from window/Fredo6-setting, but I get no response if I click on the other options.
                Daniel S
                At the Official SketchUp Blog they post about this great plugin:
                http://sketchupdate.blogspot.com/2010/04/discovering-magic-and-wonder-of.html
                πŸ‘ πŸ‘ πŸ‘
                Daniel S
                • C
                  chucky99
                  can someone tell me where to find plugins in sk 7.1
                  I installed freescale in the plugins in google/sk7/plugins,they are there and unzipped
                  but to plugins in sk7.1 in window dropdown or tools
                  dropdown. must be doing sometinnn wrong
                  thanks
                  chuck
                  • P
                    palphd
                    for some reason, i keep getting a bug splat when i try to use radial bending and change the number of slices... everything else seems to work fine though. any ideas? it used to work fine 😞
                    • fredo6F
                      Could you post the model or send it to me via PM so that I have a look
                        SnowTiger
                        I can't wait to try this plugin. I could have used this countless times in the past.
                        Before I go screwing things up though, I have a question.
                        When Extracting the files into the Plugins Folder, should the zip file create a Plugin Specific Folder ? OR Do we have to create a folder into which these files get extracted ? OR Do we simply drag all the files into the default plugins folder amongst all other plugin files ?
                        I ask because I did the latter or ended up with the latter but I see a Plugin Specific Folder called "LibFredo6 Dir 34" indicated in the following post :
                        http://forums.sketchucation.com/viewtopic.php?f=180&t=17947#p144178
                        Thanks in Advance
                        • P
                          palphd
                          thanks for the response, freedo! sure thing... it's actually not any particular model. i attached a tall box form that i just tried to no avail (changed the slice setting to 6). the pic show as far as i can get with the process, but once i designate a rotation angle, it shuts down every time, no matter what shape, model, etc.
                          by the way, i just installed updated sketchup 6 pro to version 6.4.265 recently if that makes a difference.
                          model
                          • GaieusG
                            Hi Chris,
                            Just drag and drop. There will be "bare" rb files directly under the main plugins folder and there will be some subfolders, too. Just do NOT let Windows create a main, containing subfolder under plugins (as it generally tends to do from the archive name).
                              SnowTiger
                              Thanks kindly Gaieus ... again.
                              You are truly one handy fellow. I have learned much from you, both directly and indirectly.
                              Keep up the great work .. both helping others and with your future modeling endeavors.
                              Keep on keeping on.
                              • P
                                palphd
                                i think i figured out my problem. i noticed that every time the curves were being computed in radially bending, the outliner box would tweak out just before su crashed... the next time, i closed the outliner box, tried it again and voila - everything worked fine. must not be able to handle the rapid, real time changing of groups, etc.
                                • GaieusG
                                  @palphd said:
                                  ...must not be able to handle the rapid, real time changing of groups, etc.
                                  That may wellhave been the case - as many plugins that create a great deal of geometry in a short time tend to crash or at least hang SU when the Outliner is active.
                                  • P
                                    palphd
                                    thanks gaieus... it's probably a topic that's been discussed at length in various threads, but i had been previously unaware. good to know. shut that outliner down and all is well!
                                    • fredo6F
                                      In SU6, there are reported crash with the outliner box.
                                      This has been fixed in SU7, where the outliner box refresh is suspended.
                                      I think I indicated this somewhere in the documentation, but it's good to refresh all minds.
                                        SnowTiger
                                        I keep getting a loading error when I open SU.
                                        Can someone please tell me how to attach an image (screen shot of error) that is presently on my desktop ?
                                        • GaieusG
                                          Hi Chris,
                                          IF you have saved that screenshot into an image file and answering to my post here, just scroll down a little bit until you find the "Upload attachment" tab.
                                            SnowTiger
                                            Duh ... never saw that "Upload Attachment" Tab before. Thanks
                                            Hopefully I did this right so the image is attached.
                                            FredoScale 2 Error Screenshot
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 58
                                            • 59
                                            • 21 / 59
