    Open URL on local disk
    20 Posts 5 Posters 7.7k Views 5 Watching
      Say you have a pdf help file in the same folder as the script
      help=File.dirname(__FILE__)+"/Help.pdf"
      Now use
      UI.openURL(help)
      or alternatively just hard code the 'help' variable
      as help="C:/.../Help.pdf"
        MartinRinehart
        @cjthompson said:
        ...do you have a code example?
        Hmmm. What's going on?
        # /r2/open_st_help.rb
        require 'sketchup'
        help = "/r2/sketch_talk.html"
        file = File.new( help, 'r' )
        arr = file.readlines()
        file.close()
        puts arr[0]
        puts UI.openURL( help )
        The file reads correctly. (Eliminate typos in address constant.) But doesn't open:
          A URL 'file' needs a full file-path, as used in a browser etc you need to add the Plugins folder path to the start of the rest of the path it uses ? Base Ruby manages without it ?
            MartinRinehart
            That file isn't in Plugins. It's in C:/r2/. Oddly, when I add "C:" to the location, UI.openURL() reports true, but an open file in my default browser doesn't happen.
              MartinRinehart
              Anyone?
                UI.openURL()
                Works fine for me with web-pages e.g. UI.openURL("http://www.google.com")
                and with folders/files giving the absolute path UI.openURL("C:/Program Files/Google/Google SketchUp 7/Plugins"), add /myruby.rb to open that file.
                I think you have to pass it a string for the path that is a full-path with drive etc...
                I have occasionally heard of similar problems, but sorry, I don't have a solution 😞
                Which of the above examples work for you ?
                  Sounds like it expects an URL - not a file path. Have you tried prefixing with file:// ?
                  http://en.wikipedia.org/wiki/File_URI_scheme
                    It will take a URL or absolute file path - you can then open folders, files and even applications...
                    Try UI.openURL("C:/Windows/System32/notepad.exe")
                    πŸ˜•
                    • C
                      cjthompson
                      UI.openURL("notepad.exe") or even just UI.openURL("notepad") will also work.
                        MartinRinehart
                        You never know when one little factoid will solve a problem.
                        I tried notepad (it works), then notepad++ (also works) and then an HTML file. It opened the HTML, but it opened it in Notepad++.
                        Now if only I can figure out how to specify both program and file ...
                          What is your default html opening program ? Notepad++.exe ?
                          • Dan RathbunD
                            Dan Rathbun
                            This a problem specific to your machine Martin, because you have overridden the HTML &Open file association to open in Notepad++ instead of leaving it pointing to your default browser (IExpore).
                            You should have instead had the &Edit association pointing to Notepad++, and left the &Open as it was.
                            So it is not a problem for your users... it's personal problem. 🀣
                            To 'fix' it, open Windows Explorer, any folder (doesn't matter.)
                            • On Menu: Tools > Folder Options...* In "Folder Options" dialog, choose "File Types" tab.* [Windows will take a few mins to build the list]* In list, (with 1st item selected,) click the "H" key to scroll down to the H extensions.* scroll a bit more to show HTM and HTML extensions* highlight each in turn, click the "Advanced" button* In "Edit File Type" dialog, highlight "Open"* If it's NOT set to default, the "Set Default" button will be enabled, so click it to restore normal htm/html broswer open.* If it's set to default, the "Set Default" button will be greyed (disabled,) and it's properly set.I'm not sure if you will need to log off, and back on to see changes reflected.
                            I'm not here much anymore.
                              MartinRinehart
                              Folder Options has disabled what I need:
                              I gave the user admin privileges, but that didn't help. I right-clicked in Explorer, Properties, and was able to change the default Open to a browser, getting openURL() working but that doesn't allow setting the Edit default.
                              Can I go back to KDE now?
                              • C
                                cjthompson
                                Just to make sure we aren't all going insane: what happens when you double click a .htm file?
                                  MartinRinehart
                                  I've set single click to open. An HTM opens in Chrome.
                                  • Dan RathbunD
                                    Dan Rathbun
                                    You can try going to Control Panel and right-click "Folder Options" and choose "Run As...", then pick an Administrative account to run this one applet as. (This is called running with "Elevated Privileges" in 'MS MicroSpeak'; and is more secure than having a user account always running with Administrative rights. Those slimeballs who write Trojans love people who always run with Administrative rights, especially when when connected to the Internet.)
                                    Also there is a wizard for controlling browser setings called "Set Program Access and Defaults", if you can find it on the Start Menu, you can also right-click it's icon and "Run As..."
                                    (It's actually a sub-routine of "Add/Remove Programs" and appears as the bottom button in it's left toolcolumn.) The program to run, if you have to actually right-click the file, in order to "Run As...", is:
                                    %SystemRoot%\system32\appwiz.cpl
                                    The shortcut command (in case you can't find it in your menus, and want to make a shourtcut,) is:
                                    %SystemRoot%\system32\control.exe appwiz.cpl,,3
                                    • Dan RathbunD
                                      Dan Rathbun
                                      Something like this (needs work for Mac, and can be wrapped in a method.)
                                      filename='somefile.html'
                                      path='C;/dir/dir'
                                      filepath=File.join(path,filename)
                                      if RUBY_PLATFORM.include?('mswin')
                                      if Kernel.test(?d,"#{ENV['SystemRoot']}/ie9")
                                        browser="#{ENV['SystemRoot']}/ie9/iexplore.exe")
                                      elsif Kernel.test(?d,"#{ENV['SystemRoot']}/ie8")
                                        browser="#{ENV['SystemRoot']}/ie8/iexplore.exe")
                                      elsif Kernel.test(?d,"#{ENV['SystemRoot']}/ie7")
                                        browser="#{ENV['SystemRoot']}/ie7/iexplore.exe")
                                      elsif Kernel.test(?d,"#{ENV['SystemRoot']}/ie6")
                                        browser="#{ENV['SystemRoot']}/ie6/iexplore.exe")
                                      elsif Kernel.test(?d,"#{ENV['SystemRoot']}/ie5")
                                        browser="#{ENV['SystemRoot']}/ie5/iexplore.exe")
                                      else
                                        raise(Errno;;ENOENT,filepath)
                                      else # Mac
                                        # browser = ???
                                      # open specific file in broswer
                                      f = IO.popen("#{browser} #{filepath}")
                                      EDIT: It looks like the PC browser location (for all versions) can be simplified to:
                                      browser = "#{ENV['ProgramFiles']}"<<'/Internet Explorer/iexplore.exe'
                                      It may be that the hidden system folder "Windows/ieX" is a install folder.
                                      • Dan RathbunD
                                        Dan Rathbun
                                        Hey Martin, what's the fullpath to the Chrome executable on your PC ??
