    Boolean operations
    20 Posts 12 Posters 12.2k Views 12 Watching
    • bagateloB Offline
      bagatelo
      Thank you for the answer, yes, I know that tool, I miss her when I use the 3dsMax. But would it be interesting to do operations boleans with Groups, would not it be?
        Works also with groups & components! 😉
        Order of selection indicate who is the volume to intersect!
        • bagateloB Offline
          bagatelo
          That creates edges in the places where the groups are dashed. But I want a script to make that automatically: That it is possible to subtract an object of other, as in any application 3D.
            Intersecting (and the lines created) always happens in the context you are in. So if you want to intersect a group with other geometry,you have to be in its editing context otherwise the group itself won't be affected by the intersection.
            • free agentF Offline
              free agent
              but intersect doesnt automatically create/delete the faces that are booleaned, sure there are techniques for doing this but rubie scripts make it all easier... i think it would be very handy
              http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
              • bagateloB Offline
                bagatelo
                Thanks Free Agent.
                A soul in that world understands me. Glory to God!
                I don't understand anything of Ruby Script, me leaning that it would be very easy to do a script to do that.
                • O Offline
                  orei
                  This script.. is what i need!!!
                  Because.. i need to do a render with vray of a section cut.. but vray doesn't render the section.. it consider the whole of model.
                  The trick to do this, is erase the other side that is hide by the section plane.. but if you have many groups in your model.. there are 2 ways:
                  1. create a plane with rect.. end place it in the same place of the section plane, and then.. place it in EVERY GROUP THAT YOU HAVE IN THE MODEL.. intersect and then erase..
                  2. create a plane with rect.. and EXPLODE all the groups in your model.. intersect.. and then.. erase (always in parrel view.. it's better..)
                  But.. in the first situation.. if you have a big model.. NEEDS MORE AND MORE TIME.. in the second situation.. if you need the block for material, or anithing else.. you can go crazy to recreate them..
                  A solution.. imho.. will be.. a script that:
                  1. can intersect WITH WHOLE THE MODEL.. indifferent with the group..
                  2. if you use.. a 2d plane (in any position in the 3d space..).. one of the 2 side of this place, can mean that all the bit that are in front of this side.. will be mantained.. and whole the bit in front of the other side.. will erased..
                  The best.. will be a script that work with section plane.. and when i call this script a windows screen appair and allow me to save the model that it generate, with an other name (ex. model_SECTIONX.skp)..
                  Is a dream?? i will do it.. but i don't know from where can start.. 😛
                  Thanks a lot my friends.. hope in the future!!!
                  • O Offline
                    orei
                    anyone?? come on guys.. i think that there is an alternative method to do this..
                    • F Offline
                      fellanamedlime
                      I know its an old post guys, but one word: Zorro.
                      Still looking for a proper way to do complex booleans in sketchup without manually deleting though..
                        Bool Tools
                        http://www.smustard.com/script/BoolTools
                        • N Offline
                          Napper
                          I use BoolTools as well. Does anybody happen to know if BoolTools is still being developed. It's been lingering around Version 1.000 for quite a while now. More often then not it works fine as long as the geometries in question are simple. Still I have enough cases where the Difference Tool messes up my group completely. Plus some options would be nice like not deleting the stamp when using the difference tool and stuff. Or is there a new alternative to BoolTools that I am not aware of?
                          • W Offline
                            Whaat
                            There may be a update to BoolTools at some point but probably not for a long time. One way to keep the stamp for the difference tool is to first select the stamp and press 'Ctrl+c' to copy, then perform the boolean, then use the 'paste in place' command. It's a bit clunky but it works.
                            • pep75P Offline
                              pep75
                              A bit strange though that I've paid some money for a plug-in you can hardly call a "beta"-release. I think 9 of the 10 times I use this plug-in it doesn't work properly. It just doesn't do the job. Why ask money for it then? The author admids its not that perfect; "It's a bit clunky but it works". Well it's a bit clunky but it doesn't work....shame of the money.....
                              • W Offline
                                Whaat
                                By 'clunky' I was referring to the workflow for keeping the 'cutting' geometry, not the plugin itself. From my tests and from user feedback, the plugin works very well. The times when it does not work are almost always due to an issue/bug with SketchUp itself, not the plugin. (i.e. the inability of SketchUp to create very small edges and faces).
                                If you are unsatisfied with the plugin, send an email to Smustard and you can get a refund.
                                Regards,
                                Dale
                                • gonashviliG Offline
                                  gonashvili
                                  yup most of the time bool tools needs cleanup even after dissecting simple components, which is a big shame to ask money for such a thing. i mean its kinda neat, but coulda draw the darn thing by hand 10 times by now if I didn't had to go to paypal and pay for it, extract the zip and complain about it hahah
                                  oh well
                                  OSCoolean doesn't seem to work either. I think such a thing should be worked out by Trimble into the core of Sketchup.
                                  • cottyC Offline
                                    cotty
                                    oh well
                                    You have SketchUp PRO and don't know the solid tools ? 😕
                                    my SketchUp gallery
                                      gonashvili
                                      actually no
                                      Hey, nobody knows everything, thats why I'm on here 😄
                                      • cottyC Offline
                                        cotty
                                        @gonashvili said:
                                        actually no
                                        👍 Then you are right here...
                                        my SketchUp gallery
