    ⚠️ Attention | Having issues with Sketchucation Tools 5? Report Here
    Using sketchup for a light study
    3 Posts 2 Posters 1.1k Views 2 Watching
      azz00
      Hi all, basically I am trying to use Sketch-up 7 to preform a light study.
      I understand how to use the shadow toolbar etc, however, I need to do an internal light study and obviously to be able to see the shadows I need to hide the external walls.
      But when I do this, the shadows are obviously changed because Sketch-up see's the wall as no longer being there?
      I was just wondering if there is a way that I can hide the wall, but Sketch up will treat it as being still there and keep the shadows as they should be?
      Thanks.
        Apply a transparent 'png' texture material to the external walls you want to see through - you can see through it but if its opacity is set high enough then it'll still cast shadows...
        Here's one TransparentDummy.skm
          azz00
          That is exactly what I was looking for!
          Thanks yet again man.
