    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
        MarkEMark
        Thanks TIG... I'll try that. I thought it might exceed the plug in's capability... Thanks again for the pic/explaination.
        Mark
          MarkEMark
          OK... this is embarrassing: I've forgotten how to cut the tabs off... Which command will sever them at the cut line..?
            maxandvv
            cool! I like it!!
              albayzem
              @ben ritter said:
              Chris, I can hardly keep up with your wonderful scripts. Most importantly though, you are very much appreciated for your kindness to the SU community.
                I thought I posted a reply to this... ๐Ÿ˜•
                Read the notes in the image..................
                Make sure that you draw lines all round the tabs so they select separately.
                Then select all of the tab's geometry and group it, then rotate the group etc etc...
                  madorney
                  Hi - Can anyone help a poor soul find out how / where to download Shape Bender for Mac? Thanks!!!!
                    MarkEMark
                    Hey TIG:
                    Thanks again. You did send me a PM on this. I posted this question about how to cut the tabs off before I PMed you. I posted the question a couple of days before I sent you the PM. I apologize if it appeared that I was badgering ya!
                    The PM detailed how to do this perfectly. Thanks again!
                    Mark
                    • Chris FullmerC Offline
                      Hi Mark, the download is in the very first message in this thread. so go back to page 1 and scroll down to the bottom of my first post. You will also need to install progressbar.rb from smustard. There is a link to that in my first post also. Good luck!
                        madorney
                        Hi Chris - I've managed to install the Shape Bender Plug-in, but it doesn't seem to work at all on my Mac. The tool clearly shows up under my Plugins menu, and I'm able to place the tool icon in my toolbar. But as I follow your video-tutorial to a tee, it's not working: I'm able to select the component, then the Shape Bender tool. But then I'm unable to select anything at all (nothing highlights). Help?
                        Thanks so much!
                          It sounds like maybe your straight line is not placed ont he red axis. And if your axis has been altered from its original orientation, then that will mess things up. So try resetting the global axis, then align the straight line to the red axis. See if that works. If not, could you upload a small test model?
                            truffel50
                            Wonderfull plugin! Very Thanx
                            truffel, Netherlands
                              berniedog
                              Chris,
                              This looks exciting. I guess I'm a noob,
                              but I do not know where to download
                              the shape bender plugin????
                              Thank you so much!
                              bob
                                Chris,
                                Thank you so much!
                                bob
                                At the end of the first post in this thread.
                                  berniedog
                                  Thanks Thomas for the quick reply!
                                  Found the link, I originally thought
                                  it was the french version- Cheers- bob
                                    christos88
                                    Just downloaded the Plugin, but when I tried it out it didnt work: When i selected the component I couldnt do anything else (says to highlight a line along the red axis, but still nothing happens).
                                    I've also tried using models users posted here, but still no go...
                                    Any ideas? I just have to shape a facade for a project, so if worse comes to worse could i perhaps post the model here and anybody shape it for me? (i've got the curve etc)
                                      Dummhamer
                                      Thank's for this super-mega plugin!
                                        DIEGO-RODRIGUEZ
                                        chris thank you very much for this update.
                                        a query:
                                        to generate this geometry, there are irregular shapes.
                                        Why?
                                        I'm doing something wrong?
                                        http://img130.imageshack.us/img130/3299/sinttulo1copiapp.jpg
                                        Sin tรญtulo.skp
                                          @christos88 said:
                                          Hi Christos, please upload the model, or the small portion you are working on bending, and I'll see if I can get it to work. Sorry I missed your post a few days ago.
                                            @Diego - Unfortunately that is just a side effect of how curved shapes in 3d work. I have not figure out a mathematical way to smooth those jaggies out. I'm not even sure its possible?
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 60 / 64
