    A picture looking for an answer?
    renderpluginsextensions
    35 Posts 5 Posters 3.5k Views 5 Watching
    • soloS Offline
      Okay, 3 minutes 5 seconds.
      • soloS Offline
        With both sun and omni. 4m 14
        Notice the chimney thing you have in the back does not show texture? the problem is the naming I think, will fix it for next render.
          tomot
          great now do a scene2rendering, with your 8 core i7, and turn of the water - wave end view layer. thanks!
          [my plugins](http://thingsvirtual.blogspot.ca/)
          tomot
          • soloS Offline
            It was on in the above render also.
            I will render scene 2 in a little while.
            The thing about vray render times that needs to be said, like the above scene, even though it rendered pretty fast once it gets past the scene processing, it's the scene processing that takes longer than the render, IMO that's a handicap as during the processing it uses only one core, so render times are not accurate.
            And this has to take place every single time one hits render..
            • soloS Offline
              Okay, scene processing 4mins 33s, render 4mins 07 secs = 8m 40s
                Solo: are you using the latest VfSU release - or the same version as tomot?
                  tomot
                  ahhhh!.....the missing word is.... OFF πŸ˜„
                  I also want to try your displacement map idea, do you have a suitable displacement map?...or anyone else!
                  tomot
                    tomot
                    I'm now onto the new beta version. and my old scene, without adjustments, now suffers from blowouts!
                    tomot
                      The Default Light appear to be brighter in this version.
                        tomot
                        Sorry, the above picture, with its blowout lighting, was rendered with version v1.48.66.
                        I have now installed v1.48.67, and giving it a try.
                        I tried to render the same Scene, however after 50 minutes the, Building Photon Map process was only 70% done, hence I abandoned, the Rendering process. Something is clearly wrong!
                        thomthom, you still have my file and png's of my settings. Perhaps if you have time, you might give it a try.
                        tomot
                        • 2 / 2
