    Castle Howard
    72 Posts 56 Posters 30.5k Views 56 Watching
    • FletchF Offline
      Fletch
      hmm... too bad about the component leveraging... as it also makes for much faster model processing and rendering and better RAM usage... maybe keep it in mind for your next monster project. πŸ˜„
      well, it's a pain, I'm sure, but you can export different sectors of the model, north wing, south wing, etc, then merge them all together in one big model in KT... but it should (KT) handle the polys just fine.
      People do this all the time, usually its a matter of separating furniture from architecture... but in your case could be castle "wings". πŸ˜‰
      Fletch
        Glenn at home
        This model needs to be the response that people get when they say that SU is not a professional tool! Excellent job. πŸ‘
          Sir
          amazing
          • dermotcollD Offline
            dermotcoll
            Absolutely stunning modelling. I am totally blown away by the sheer size of this project. Very very well done
            πŸ‘ πŸ‘ πŸ‘ πŸ‘ πŸ‘
            When you burn your arse - you gotta sit on the blisters!!
              Fantastic modeling... Hats off ! 😍
              History lesson; 'Castle Howard' is a wonderful example of an architectural masterpiece that was not designed by an architect - [Sir] John Vanburgh was a dilettante, playwright and stage-set designer etc - who only got the job after the rejection of initial designs by the respected architect William Talman, because Vanburgh's pal, and luckily the client, Charles Howard [3rd Earl of Carlisle] was a member of the his club - the 'Kit-Cat Club' !
              [A ''kit-kat / 'club' is now a definitely [one or two] good chocolate-bars to most Brits and probably conjures up a seedy strip-joint to most Yanks... 🀣 ]
              To continue... Vanburgh had some great ideas... but let's not forget that he was 'assisted' by Nicholas Hawksmoor [as he also was at Blenheim Palace]... who knew what he was doing since he had worked with Wren*.........
              In Colvin's words, "[Hawksmoor] enabled Vanbrugh's heroic designs to be translated into actuality."
              i.e. Hawksmoor got Vanburgh out of the s**t !!!
              Additionally, don't forget that Sir Christopher *Wren was actually a mathematician cum surveyor who turned out to be one of England's best 'architects' - although I'm always a bit suspicious of how quickly he came up with the new master-plan for London after it burnt down in the 'Great Fire' of 1666 - even with CAD we'd've been hard pressed to turn that out so quickly... did they search him for matches ??? πŸ˜‰
              • FletchF Offline
                Fletch
                @tig said:
                ...to turn that out so quickly... did they search him for matches ??? πŸ˜‰
                πŸ˜† (sorry to go off topic momentarily...) Thanks for the bit of history TIG! πŸ‘ I love this stuff.
                No, I'm actually positive there were several plans already laid for London before the burning. Most large cities have master plans, even at that time, city planning was a big deal. But that his was chosen over others, there's something to ponder... doubtless much politics involved... same deal now... just look at politics around 1 World Trade today 🀒 πŸ˜’
                Fletch
                • IdahoJI Offline
                  IdahoJ
                  An amazing piece of work. A wonderful example of what can be achieved with research, diligence and just plain "work a bit at it every day" kind of work. Very nice!
                  Cheers!
                  "For a moment, nothing happened. Then, after a second or so, nothing continued to happen."
                  • jamalitoJ Offline
                    jamalito
                    By the way
                    I do not have any comment until I would say my comment
                    This design is wonderful
                    I have two questions
                    How many years you had worked on this design? πŸ˜†
                    What is the program that you used in Render?
                    Albert Einstein:
                    ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                    • FletchF Offline
                      Fletch
                      your questions are answered in his first post. πŸ˜†
                      Fletch
                      • Al HartA Offline
                        Al Hart
                        IRender nXt and nXtRender are two versions of the nXt rendering engine integrated into SketchUp. take a look at: IRender nXt
                        Al Hart
                        IRender nXt from Render Plus
                          MartinPh
                          I've been experimenting a bit with field of view, and played around in Photoshop with the result. I need to do something about the glass material, it doesn't look very good...
                          http://imgur.com/IFbvz.jpg
                          • N Offline
                            notareal
                            A grand project! Last render needs environmental reflections for windows and a perspective control lens (shift). Also perhaps instanced grass and displaced gravel. DOF feels a bit unnatural, is that post pro?
                            • broomstickB Offline
                              broomstick
                              Just.. Awesome. I hadn't seen this thread!!
                                Cyberdactyl
                                Very impressive. Awesome attention to detail!
                                I was just curious about those textures on the walls to the left in the last pic?
                                Does iRender have turbidity as a variable? It would really give your work a feel of distance.
                                  MartinPh
                                  Hi Cyberdactyl, no, unfortunately iRender doesn't do turbidity (yet?). Their image editor offers haze as a post-render processing option, but that didn't do much for this model. And the texture, well, it's a lame attempt at dirtmapping done in Photoshop... I would need procedurals to do it inside the render application, another option iRender doesn't have. I am so hoping some day the Vray people will finally fix their awful latest release, which is unable to render a model this size, and which has been sitting around uselessly on my PC ever since I, misguidedly, bought it... 😑
                                  • soloS Offline
                                    This great model needs Vue, well done mate.
                                    • N Offline
                                      nektares
                                      wow thatΒ΄s so amazing. i Love it the model is so well done
                                      even without shaders it looks amazing, excellent job.
                                      a bit of work with the landscape would be the cherry on the cake.
                                      Congratulations!!!
                                        richcat
                                        Hi Martin which version of IRender as you using as IRender nXt has procedural bump maps, and auto texture bumpshttp://wiki.renderplus.com/index.php?title=Procedural_Bump_Maps, the cheaper trimmed down version nXtRender does not.
                                        • N Offline
                                          nektares
                                          This is amazing, i love it!
                                          • leedeeteeL Offline
                                            leedeetee
                                            Just seen this and it is AMAZING! I live in the centre of York and have been many times, your model has made me want to go! Inspirational stuff. Makes me feel very humble!
                                            • 3 / 4
