    Renvoyer des surfaces vers tableur ?
    17 Posts 6 Posters 2.0k Views 6 Watching
    • DVERGERD Offline
      DVERGER
      Est-ce qu'il existe un moyen de renvoyer les surfaces d'un objet (simple) vers un tableur ?
      L'idéal serait de pouvoir distinguer les surfaces par "familles" (Mur, Toit...)
        Il faut demander à TIG, si cela se fait en 10 minutes il te le pond! ☀
        C'est la maison de Homer? 💚
        Allez je lui demande en PM 😉
        • DVERGERD Offline
          DVERGER
          Super sympa!
          t'hoooooo
            require 'sketchup.rb'
            def reportfaces()
              model=Sketchup.active_model
              mpath=model.path
              if mpath==""
                UI.messagebox("This 'Untitled' new Model must be Saved\nbefore making Face Report !\nExiting... ")
                return nil
              mpath=(mpath.split("\\")[0..-2]).join("/")###strip off file name
              mname=model.title
              entities=model.entities
              ss=model.selection
              ssa=ss.to_a
              ss.clear
              es=[]
              model.start_operation("Face Report")
              csv=mpath+"/"+mname+"-Face_Report.csv"
              begin
                file=File.new(csv,"w")
              rescue### trap if open
                UI.messagebox("Face Report File;\n\n  "+csv+"\n\nCannot be written - it's probably already open.\nClose it and try making it again...\n\nExiting...")
            	return nil
              file.puts("FACE-REF,LAYER,AREA,MATERIAL\n\n")
              ### title ### add what you want to list here
              faces=[]
              ssa.each{|e|faces << e if e.class==Sketchup;;Face}
              faces_data=[]
              faces.each{|face|
                data=[]
                data[0]=face.id.to_s
                data[1]=face.layer.name
                data[2]=(face.area * 0.000645160000).to_s ### sq" >>> sqm
                if face.material
                  data[3]=face.material.display_name
                else
                  data[3]=""
                end#if
                faces_data << data
              faces_data.each{|data|
                file.puts(data[0]+","+data[1]+","+data[2]+","+data[3])
              file.close
              model.commit_operation
              puts "Face Report Made ; "+csv
              return nil
            end#def
            Here it is.
            Select what you want reporting.
            Any Faces are reported in a CSV file,
            FACE-REF, LAYER, AREA, MATERIAL.
            Translate into FR as you like.
            Copy/Paste this code into a new file in the Plugins folder, called reportfaces.rb.
            Use Notepad.exe to make it.
            To run the tool type reportfaces.rb in the Ruby Console.
            Ici.
            Sélectionnez ce que vous voulez renvoyer.
            Toute faces sont renvoyés dans un fichier au format CSV.
            Traduire en FR que vous le souhaitez.
            Copier/Coller ce code dans un nouveau fichier dans le dossier Plugins, appelé reportfaces.rb.
            Utilisez Notepad.exe pour le faire.
            Pour exécuter l'outil tapez reportfaces dans la Console Ruby.
              Thx for them ! 😎
              • DVERGERD Offline
                DVERGER
                Merci, merci et encore merci.
                la communauté SU est vraiment incroyable. Et Sketchup est incroyable aussi!
                J'imagine qu'on peux aussi lister des composants, par exemple 3 fenetres de 80125 + 2 fenetres de 140215 + 4 chassis de toit de 114*118 + 1 porte de garage + etc...
                  psylo
                  Du métré dans Sketchup !
                  Héhé, Archicad va bientôt avoir du souci à se faire dans l'agence ! 😄
                  • DVERGERD Offline
                    DVERGER
                    Oui 😳 mais la ce serait vraiment super.
                      vous abusez 😄
                      j'ai fait derechef la requête 😉
                      Vous aurez peut-être que la liste des composant brute
                      On peut utiliser excel pour faire la somme d'un élément identique 😉
                        There is already ComponentReporter++.rb which reports in a CSV, for components etc...
                        Il ya déjà ComponentReporter++.rb qui rend compte dans un fichier CSV, pour les composants, etc...
                        • DVERGERD Offline
                          DVERGER
                          OK, ca roule.
                          • PatrickP Offline
                            Patrick
                            Bonjour,
                            je viens d'essayer et cela fonctionne très bien mais il faudrait prévoir de choisir l'emplacement du fichier Csv.
                            Je travaille sur un serveur et le plug n'arrive pas forcément à écrire sur le serveur (j'ai pourtant les autorisations pour cela), aussi il m'a fallu enregistrer mon fichier SU sur mon poste avant de pourvoir générer le CSV ! Sur un autre fichier cela ne m'a pas fait le problème.
                            Très intéressant ce plug car il sort bien le quantitatif de l'assemblage. Par contre il faut prévoir de ne pas mettre des accents dans les noms des composants pour ne pas voir des *£$ dans la liste (Péré en Péré il faut comprendre !)
                            Cordialement
                            Patrick
                              Tony.3ds
                              Excuser mais je n’ai pas compris comment ça marchait ?
                              Win10 64bits | Intel Core i7 4790k 4 GHz | NVIDIA GTX 970 | 16 Go DDR3
                              iMac Retina 5K OSX 10.13.6 | Intel Core i7 4 GHz | AMD Radeon R9 | 16 Go DDR3
                              • DVERGERD Offline
                                DVERGER
                                Tu lances le plug et tu obtient un fichier que tu peux ouvrir dans un tableur.
                                Ce fichier contient des valeurs exploitables avec quelques formules excel.
                                  Tony.3ds
                                  Ok mais c'est le plug que je ne trouve pas?
                                    Il semble qu'il y en ait quelques versions successives ici 😉
                                    • PatrickP Offline
                                      Patrick
                                      A priori c'est la dernière qu'il faudrait utiliser
                                      Type : Tool
                                      Description : Makes reports on components etc in a model...
                                      Based on ComponentReporter+
                                      Menu Item : Plugins >> Component++ Report
                                      Usage : (bla bla bla ...)
                                      Version : 1.0 20080722 First Issue.
                                      Après redémarrage de SU on le trouve dans le menu Plugins ...
                                      Patrick
