    Render parallel projection views
    renderpluginsextensions
    6 Posts 4 Posters 4.0k Views 4 Watching
    • O Offline
      ozzidora
      I've three questions about Vray:
      1- How can I obtain a rendered image of a viewport in parallel view mode such as front view or axonometric view?
      2- How can I obtain a rendered image of a viewport with matched image (in the tag of the viewport name it appears "(2D)" suffix), I suppose it's a camera setting problem...
      3- How can I obtain smooth shadows without rough appearance like the attached image?
      thanks
      • O Offline
        ozzidora
        comunque grazie per le numerose risposte, buffoni
          You can't expect immediate response. There aren't people always around. And maybe noone has an immediate answer. No need to be like that. Remember you also that you have the ASGVis forum.
          1. I've not rendered any parallel views. But I've seen posts at ASGVis forum talking about it.
          2. Photomatched image? I've had no problems with photomatched scenes.
          3. What is the light source? What light engine do you use?
          p.s. please state what version of VfSU you use as the various versions behave differently in some areas.
          • chrisglasierC Offline
            chrisglasier
            Google translation:
            "anyway thanks for the many responses, clowns"
            charmo italiano!
            • O Offline
              ozzidora
              thank you thomthom to be so patient, (I'm tired: too much work).
              I've tried rendering in parallel view and naturally NOW it works, also in photo matching...except in the only one that I needed. I can't divulgate it because it's a contest.
              The Vray version is 01.05.30.
              3- I use sun light source with the parameters in the attached image.
              ("charmo" means nothing in italian, but I don't care about it)
              • StinkieS Offline
                Stinkie
                @chrisglasier said:
                Google translation:
                "anyway thanks for the many responses, clowns"!
                Yeah, I ran it through Google's translator as well.
                Ozzidora, do you always insult people for not helping you fast enough to your liking? I suggest you either reconsider your attitude or pack up and leave.
