    [Plugin] Cyma Curve Tool
    39 Posts 16 Posters 30.5k Views 16 Watching
    • MALAISEM Offline
      MALAISE
      Thx TIG
      You've done a pretty good Job. I'm sure you enjoy coding ๐Ÿ‘
      MALAISE
      La Connaissance n'a de valeur que partagรฉe
        Thatnks TIG - again!
        This will definitely be very handy for my ogee arches (which I would probably use more often than cymas)
          Here's an update http://forums.sketchucation.com/viewtopic.php?p=230584#p230584
          v1.4 20100311
          Non-square forms now possible and sizes entered, X & Y.
          VCB prompt now shows the chord-proportion value needed to get tangential ends - useful if it's a non-square form.
          The arcs' segments can now be set.
          'Gola' and 'Ogee' added to type descriptions.
          Notes and lingvo files updated to match changes.
          ๐Ÿค“
            dedmin
              I assume you refer to the 'broken curve' ?
              It's down to how the arcs are drawn - I'll fix it ๐Ÿ˜’
                v1.5 The 'broken' curve/arc glitch is fixed and the form is now a welded curve made from the two arcs...
                  dedmin
                  ๐Ÿ‘ ๐Ÿ‘
                    lapx
                    Thanks TIG!
                      troyhome
                      i updated and now i get an error when starting su:
                      Error Loading File CymaCurveTool.rb
                      undefined method `deBabelizer' for main:Object
                      i'm on a mac
                      IOviz.com
                      SU Pro 2024 PC
                        There is a file in the zip file called 'deBabelizer.rb' - this goes into the Plugins folder ???
                        • Y Offline
                          youemailme
                          Three cheers! You've saved me loads of time, this is a much needed tool! My (paypal) check's in the mail!
                            Thank, I have it already [ยฃ]... watch out for some other tools that are in the pipeline... ๐Ÿค“
                            • H Offline
                              hebeijianke
                              TIG: Here's the Chinese lingvo file
                              CymaCurveToolZH-CN.rar
                                Thanks. I'll add it to a future update - in the meanwhile any users wanting Chinese locale lingvo can extract this and put it into their ../Plugins/TIGtools/ folder... ๐Ÿ˜„
                                  troyhome
                                  I had used a different deBabelizer version instead of the one included with this plug, so simply replacing that with the one included... well, that fixed it! thanks ๐Ÿ˜„ ๐Ÿ˜ณ
                                  IOviz.com
                                  SU Pro 2024 PC
                                    All current versions of deBabelizer.rb are identical so it shouldn't cause problems, as long as you have one - I distribute a copy of it with each tool that will use it in case you haven't already got a copy in Plugins...
                                    It's the tool needed to translate the wording of prompts and dialogs etc to your 'locale' language, if there's a 'lingvo' file found to match it - most commonly these are EN-US [English - the base default], and FR[ench] and ES[panish], and sometimes ZH-CN [Chinese] or other 'locale' codes - but any 'locale' that's returned by the system is supported if you copy/rename a lingvo file and translate the phrases in it... If you are picky you could even 'translate' the base EN-US lingvo version so it says different things - e.g. 'colour' vs 'color' if you are not American but you have a EN-US locale - or even into 'Esperanto' phrases etc where that is not an official 'locale' !
                                    ๐Ÿค“
                                    • F Offline
                                      function
                                      Hi TIG - thanks for the great tool : I'm experiencing this glitch in 8 using 1.5 -
                                        I tested it with exactly the same dialog and Units settings and it works fine for me - the only difference is I have Vista rather than XP, but that shouldn't make any difference ๐Ÿ˜•
                                        At first I thought it might be because you had units displayed and accuracy set to no dp's - 4" versus 4.000 BUT that makes no difference to me either...
                                        Can you get it to work with other permutations of settings or Units ?
                                          I just tried it with the same settings, V8 on XP and had no problems with it.
                                          • Bob JamesB Offline
                                            Bob James
                                            @tig said:
                                            Here's an explanation of the the 2 types of Cyma Curve...
                                            I tried to use this to make pipe transitions: bend the pipe x-inches and continue in the original direction.
                                            A ratio of 1.414 does not result in vertical for me (both ends do not extend parallel)
                                            Also, a "follow-me" circle most often results in a long tapering cone off of the opposite end! ๐Ÿ˜ฎ
                                            • 2 / 2
