    Having trouble with Component Stringer Plugin
    5 Posts 3 Posters 296 Views 3 Watching
    • leedeeteeL Offline
      leedeetee
      Please can anyone tell me what I'm doing wrong with the Component Stringer plugin?
      I'm following the instructions, selecting everything and then running the plug-in, but this happen!
      Any help much appreciated!
      Before!
      After!
        You have to have the component's blue-axis facing along the path's lines; also you are scaling the fence panel to fit each segment of the path - only do it in length ?
        Or divide the straight parts to nearer the arc's segmentation ?
          leedeetee
          Yep, even when the blue axis is aligned, I still get the above results.
          I've not scaled the fence panel at all, it is straight from the components.
            See the illustration I've added...
            • Chris FullmerC Offline
              Yeah, the blue axis seems to be point the right direction, but you need to adjust the red and green ones. You'll notice it is lined up correctly end to end, its just lying on its side. THat is a green/red issue.
              An easy way to do it is to edit the component and rotate the geometry so it is standing up. OR you could change the component axis before using component stringer.
              And component stringer is not necessarily the best script for laying out things like fences onto a line. CompStringer really excels at things that can change scale. I would recommend using Rick's path_Copy from smustard.com. You will probably get better results and more relable.
