    Incremental rename bunch of components
    9 Posts 5 Posters 873 Views 5 Watching
      dedmin
      Is there a plugin to incremental rename bunch of components:
      name#N
        remus
        If it doesnt exist itd be pretty easy to make.
        Just to clarify, is the "name" in "name#N" constant?
          And DefinitionList.unique_name does most of the job:
          http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/definitionlist.html#unique_name
          The unique_name is used to generate a unique name for a definition based on a base_name string. For example, a base_name of "Joe" might return "Joe #2"
          Iterate the selected instances, collect the definitions.
          Iterate the definitions naming them by what DefinitionList.unique_name.
          Bob's your uncle.
            dedmin
            Yes. Something like this - cab#1, cab#2 ...
              Copy/paste this code into a file called componentrenamer.rb in the Plugins folder.
              To run it you type componentrenamer "NewName#1" in the Ruby Console to change the name of selected component-instances' definitions to NewName#1, NewName#2, NewName#3 etc...
              Note: starting with ' NewName' increments the second one to ' NewName#1'
              def componentrenamer(newname)
                model=Sketchup.active_model
                ss=model.selection
                defs=[]
                ss.each{|e|defs << e.definition if e.class==Sketchup;;ComponentInstance}
                defs.uniq.each{|d|d.name=model.definitions.unique_name(newname)}
              end#def
              πŸ€“
                dedmin
                Just perfect!!!!
                Here it is. Thanks TIG!!!
                componentrenamer.rb
                  alz
                  Nice!
                  I'm guessing the # sign is part of the internal SketchUp API? #s cause some problems with how I use models externally. I looked at the (dang simple) code and didn't see any immediate way to suppress the #.
                  This is for keeping all instances the same component, but using a different name, correct? It's not taking all instances and making them unique when renaming? (Similar to what happens when two components of the same name come in but are different -- the second one is named: name#1.)
                    To strip the # try adding an extra argument
                    def componentrenamer(newname,nnn=nil)
                      ss=model.selection
                      defs=[]
                      defs.uniq.each{|d|
                        unn=model.definitions.unique_name(newname)
                        unn=unn.tr("#",nnn)if nnn
                        d.name=unn
                    end#def
                    The second string in the translation tr nnn can be anything you want - e.g. "-" or "_" ?
                    The usage now has an optional second argument to replace the # with something else
                    e.g. componentrenamer("NewName","_")
                    If you don't add it then the # remains unchanged...
                    πŸ€“
                      alz
                      Thanks TIG! I'll try it out (and learn a little more about SU Ruby)
                      πŸ˜„
