    Idea: show console on script error
    13 Posts 7 Posters 1.2k Views 7 Watching
      jessejames
      Hello,
      I think it would be a great idea to show the ruby console anytime a script throws an error. Now before the lemming "protectors" start their wailing and gnashing of teeth, yes we should have a menu item in SketchUp like... "Show Console on Script Error" (minimized of course). Or maybe a Ruby command would be a better idea -- keep the "lemmings" from taking the proverbial "swan-dive to hell"
      πŸ˜‰
      Always sleep with a loaded gun under your pillow!
        remus
        Sounds like a good idea to me πŸ‘
          Perhaps something like...
          begin
            ### do all of your code here
          rescue Exception => e
            Sketchup.send_action("showRubyPanel;")
            puts e.message
            jessejames
            @tig said:
            > begin
            >   puts e.message
            > end
            Great idea TIG!
              Jim
              The Ruby Console is not required to be visible for using stdout, and SketchUp doesn't wait for the Ruby Console to be opened. The puts will be long finished before the Ruby Console has a chance to appear.
              A messagebox might work. Or if you want the Ruby Console, you could queue the messages until it is open.
                Jim
                Another technique I have used is to redirect stdout and stderr when starting SketchUp.
                In a .bat file, I run SU:
                "c:\Program Files\Google\Google Sketchup 7\Sketchup.exe" 1> _sulog.txt 2>&1
                When the Ruby Console is open, output goes there. WHen closed, it goes to the _sulog.txt file.
                This is not a perfect solution because the output is buffered, and in the case of a BugSplat, the buffered output is lost. I tried flushing the output buffer using a timer, but haven't been successful so far.
                A better solution is to write output to a file from Ruby. One option is to redefine puts to write to a file instead of stdout. Another option is to create your own log method for debug output.
                def log(s); File.open("log.txt", "a") { |f| f.puts(s) }; end
                (Not efficient with all the file handle opening and closing, but it works and output is flushed immediately.)
                Then use the (unix) command tail -f log.txt to follow the output log.
                You might then want to truncate the log file when SU starts, maybe writing the date and time to it.
                • Dan RathbunD
                  Dan Rathbun
                  Has anyone tried running the standard Ruby simple logger (logger.rb) under SU embedded Ruby?
                  It looks easy to use. Example from logger.rb RDoc
                  (with module wrapper, require statement and method wrapper added by me.)
                  # A simple example ...
                  module A_Logger_Test
                  require 'logger.rb'
                  def log_file_error( path )
                    log = Logger.new(STDOUT)
                    log.level = Logger;;WARN
                    log.debug("Created logger")
                    log.info("Program started")
                    log.warn("Nothing to do!")
                    begin
                      File.each_line(path) do |line|
                        unless line =~ /^(\w+) = (.*)$/
                          log.error("Line in wrong format; #{line}")
                    rescue => err
                      log.fatal("Caught exception; exiting")
                      log.fatal(err)
                  end # method
                  end # module
                  It can also output to log files (with auto file aging and max file sizes.)
                  I'm not here much anymore.
                  • Dan RathbunD
                    Dan Rathbun
                    I solved this on a little ruby I wrote to display SU Options.
                    Here's the lister method:
                    def self.list_options(output=$stdout)
                      # param chooses stdout or messagebox
                      case output
                      when $stdout, STDOUT
                        Sketchup.send_action( CMD_RUBY_CONSOLE )
                        UI.start_timer(0.5, false) { $stdout.write( get_options_text ) }
                      when 'messagebox',;messagebox, 'MB', ;MB
                        UI.messagebox( get_options_text,MB_MULTILINE,' OPTIONS')
                    So the 'trick' is to pause for a half-second allowing the console dialog time to load and initialize, etc. So TIG's example can work like this:
                    begin
                      if $VERBOSE  # true is verbose mode
                        Sketchup.send_action(CMD_RUBY_CONSOLE)
                        UI.start_timer(0.5, false) { puts e.message }
                      elsif $VERBOSE.nil?  # nil is silent mode
                        logfile.write( e.message )
                      else  # $VERBOSE is false (medium mode)
                        puts e.message
                        raise # (optional)
                    pssst! JJ, it's not necessary to requote codeblocks unless your suggesting changes.
                    • Dan RathbunD
                      Dan Rathbun
                      ThomThom tells me UI.start_timer will not wait at all, if I set the time to anything less than 1 second.
                      So change the code above to 1.0 instead of 0.5
                      • T
                        tomasz
                        Thanks Dan! I have tested it with timer set to 0.1 and it works fine. (Win Vista/SU 8.0.4811)
                          Yea, the timer was fixed in SU8. In older version it rounds down to whole integers.
                          • T
                            tomasz
                            Thanks! I was going to check whether it works with older versions.
                              The docs should really be mentioning this. 😞
