    How ican
    renderpluginsextensions
    9 Posts 3 Posters 1.3k Views 3 Watching
    • Z
      zizo85
      hi , how I CAN SAVE SKP FILE WITH ALL VIMAT MATERIAL AND IES LIGHTING AN SETING AND ..... IF I USE SKETCHUP MATERIAL ITS ALREADY SAVED WITH THE FILE BUT IF I USE JPEG FOR VRAY MATERIAL IN DIFUSE OR BUMBOR.... AND SAVE THE FILE AND OPEN THE FILE BY ANOTHER PC SOME TEXTIRE ARE MISSED AND IES SO MY QUESTION SIMPLY DOES ANY ONE NOW AWAY TO ARCHIVE THE FILE LIKE MAX ....... IN MAX WHEN YOU ARCHIVE THE FILE HE MAKE A ZIP FOLDER CONTAIN EVREY THING ABOUT FILE JPEG TEXTURE IES FILE ANY MATERIAL LIBRARY USED ANY SETING EVEN THE JPEG SKY TEXTURE IN ENVIROMENT .......
      SO YOU CAN OPEN THE FILE AND WORK WITH ANY PC YOU WONT OR AFTER FORMAT WITHOUT MISSING PROPLEM AND WORK FINE
        Could you please edit that question to be more structured and without the caps. Very hard to read and understand your question. ❓
        • Z
          zizo85
          iam realy sory about my languge .
          the question :
          in the max to save the file with all stuff material ies file .... we make archive from file archive to make .zip file with all thing so we can open it by any computer without missing file just like the photo but in sketchup sometimes isave the file and when i use the file on defrent pc some textures are miss so does any one now the way to do somthing like archive in max...
          • Z
            zizo85
            one more question please whean i export the file from skp to 3ds the soften edges dont like soften any more and the curve face looks like broken face and some faces are realy Damages just like in the photo any help with that well be great
            • Z
              zizo85
              • Z
                zizo85
                • Z
                  zizo85
                  • V
                    vidy
                    this problem are indeed happen inside sketch up, still looking for some answer too how to manage this
                    please give any clues... πŸŽ‰
                    regards,
                    vidy
                    still so much to learn..
                      With the previous version of VfSU one trick to gather all resources where to use the Distributed Render. You don't need to use any other machines than the one you sit on. Just turn on DR and set it to save assets to a folder.
                      However, in the last release the DR is broken - need to wait for a patch.
                      As for SU to Max - I don't know.
