    Create a new material from textur
    3 Posts 2 Posters 211 Views 2 Watching
    • H Offline
      hvanessen
      Hi guys,
      When i have a very nice texture, wich i want to use often in different projects, i want it to make a material. So i only have to use the paintbucket tool and select it.
      Is there a way to convert a texture into a SU material ?
        Use
        File > Import
        on the right side there's now an extra option - ' import as texture' - tick it.
        It becomes a new material directly.
        Once you are happy with the material' settings [ Materials Browser > Model-tab > Edit etc to get the image's scale, colorizing etc right] you can also save it for direct use later in other models...
        Materials Browser > Model-tab, right-click context-menu > Save as - this let's you make a ' skm' file of it, saved somewhere in your Materials folder, which you can then use directly as a Material from the Browser in any other models, keeping those same settings...
        πŸ€“
        • H Offline
          hvanessen
          TIG,
          From me to you πŸ‘ because your solution has workt perfectly. Now i can manege my over more than 1000 textures.
