    Still looking for a good drafting companion for Sketchup...
    80 Posts 25 Posters 18.7k Views 25 Watching
    • W Offline
      watkins
      Dear Tom,
      Have you imported SU models into Solid Edge, and if so, how well did it work?
      Regards,
      Bob
        seasdes
        Regarding slowness of SU model inside DoubleCAD. - Please look up this post it may be the solution to your problems.
        Seasdes
        Using Sketchup Pro 2019
          tfdesign
          Hi Bob.
          Sorry but I've never tried doing so, because I played with Solidedge way before i'd even tried Sketchup. I imagine the wouldnt be a problem, because both apps read and write the dwg format. There's no harm in just downloading the software and trying it though.
          Regards,
          Tom
          • E Offline
            ericschimel
            Before LayOut had dimensions in it, I used to do all of my layout documents in good old AutoCAD, is that not an option for you? I used to run huge Sketchup files in AutoCad without an issue...
            -Eric
            http://plugin.sketchthis.net
            Sketchup Kitchen Design Plugin
            Custom Models
              drfabinex
              Autocad does do the trick. Although still not as fast rotating as Sketchup. Unfortunately I can't afford more than the 30 day demo price... 😳
              As a side note, out of frustration I tried Turbocad deluxe again (129.95$) and found that I wasn't using OpenGL acceleration. It sped up quite a bit (actually a little better than Autocad). Still not perfect, but hell... neither am I.
              Thanks for all your suggestions! Keep em coming. I'm kind of a software slut, i'll try anything once (and then never call it again). 😎
              • honoluludesktopH Offline
                honoluludesktop
                Could the select Open GL option be the reason for the problems you had with for DoubleCad?
                  drfabinex
                  There was a noticeable improvement on Doublecad as well but I still find Doublecad slower even with OpenGL acceleration. I think it's still Turbocad deluxe for me. Importing materials is a nice bonus as well.
                  I posed the performance question on the Doublecad forum and William Manning replied saying that they're working on performance improvements though.
                  Just to be clear: I DID NOT find Doublecad unbearable (glitchy redraws, model hanging for 5 secs on rotate) for navigating high poly models, I just found it slow enough to be frustrating with tight deadlines for drawings.
                  • sketch3d.deS Offline
                    sketch3d.de
                    why not just using ViaCAD inkl. SU import, OGL support and bargain pricing ❓
                    btw, the former TC Mac version were licensed as a OEM made by Punch...
                    Norbert
                      drfabinex
                      Tried Viacad already as I mentioned in the first post. It's SKP importer doesn't work with SU7 at all, and a DWG export from SU opened in Viacad crawls, complete with hideously choppy redraws while rotating. Not worth the cheap price IMHO. πŸ‘Ž
                      Too bad because it looked so promising.
                        rickgraham
                        Not sure I mentioned this here before but give this a try (looks promising): http://butterfly.autodesk.com/
                        Rick
                          sketch3d.de
                          @drfabinex said:
                          It's SKP importer doesn't work with SU7 at all...
                          support for SU v7 format with new VC version 7 (~4-6 weeks), until then just save in SU v6 format...
                          @drfabinex said:
                          and a DWG export from SU opened in Viacad crawls...
                          VC is a NURBS surface/volume modeler not targeted for editing meshes... thought you're looking for a 'drafting companion' for e.g. creating shop drawings based on your section cuts exported from SU.
                          If you need (another) mesh editor, go for e.g. bonzai3D or MeshLab.
                          @drfabinex said:
                          ...complete with hideously choppy redraws while rotating.
                          lame GPU or OGL support of driver, at least for the amount of polys contained.
                          @drfabinex said:
                          ...IMHO.
                          sure
                          anywayz, it's up to you
                          Norb.
                            tfdesign
                            I get the feeling that you don't really know what you want (which I too can also relate to!). All CAD software is a pain in the ar*e. It never does just quite what you want. Then it's a massive investment on top of that. I want a holiday this year, with my kids! You just have to learn the developers ways, and get on with it. 😞
                            I was going to buy Shark, then I was going to buy SketchUp, then Shark again, then Vectorworks. Then there was whiff that Solidworks were porting to Mac, then they withdrew that statement. It does my friggin swede in!!!
                            I've got ViaCAD 2D/3D, SketchUp free, MacDraft, QCad and Cheetah3D. I've done pretty damn good with those so far, so I'm sticking with them. πŸ˜„
                              drfabinex
                              What I really want is for Layout to grow up a little more πŸ˜„ (or become ruby scriptable). πŸ˜„
                              Ideally I just want a tool to QUICKLY navigate referenced (therefore update-able) high poly SKP files and allow me to do the following in 2d paperspace:
                              • choose any perspective and/or parallel view and scale easily
                              • show it in wireframe, dashed hidden line, or textured style
                              • generate section views with hatching
                              • associative coloring, hatching and dimensions,
                              • turn on/off layers per viewport
                              • multi-leader and regular text boxes
                              • basic line, rect, arc, circle, freehand tools
                              • print any size, output pdf, import raster images
                              • ability to create resizable 2d blocks
                              • ability to reference multiple SKP's
                              • customizable shortcuts
                              Beyond that I find most tools a distraction.
                              Most of the programs mentioned will do all of this. But since they navigate so slowly it's still faster for me to use a bunch of workarounds in Layout. I put up this post initially simply to be thorough in my quest for increased productivity/decreased hassle.
                              Thanks for everyone's help and suggestions! I fear I might have upset some people with my opinions on some of the software, please don't take them personally.
                              • X Offline
                                xrok1
                                you could try Alibre Design standard for $97. actually try it for free, pay $97 if you want it. πŸ˜‰
                                  dedmin
                                  Yes, Alibre and SketchUP are awesome combination. Export from Alibre into .skp is excellent:
                                  • X Offline
                                    xrok1
                                    very nice. did you use .dwg format into SU?
                                    and could we see a shot with hidden edges shown in SU?
                                      dedmin
                                      No dwg - read here http://www.cadalyst.com/cad/alibre-design-and-google-sketchup-alibre-options-tutorial-11082
                                      • X Offline
                                        xrok1
                                        oh, i see. alibre has a "Alibre 3D Publisher" addon that exports directly to SU. awsome!
                                        • X Offline
                                          xrok1
                                          very nice mesh too.
                                            honoluludesktop
                                            Maybe this is the wrong place to ask, but wouldn't a "drafting companion" to create technical drawings for SU models, best be a 2d drafting program with great document management?
                                            • 1 / 4
