    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
      arjunmax09
      but i have the progressbar ruby script in English only ... my shape bender isn't workin' yet... ๐Ÿ˜ž
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
      • DVERGERD Offline
        DVERGER
        @tig said:
        It's the name of the file it's trying to load fr_ progressbar.rb !
        Still doesn't fix the other some files in the wrong folder possible problems...
        Mon dossier Shape Bender (dans le dossier Plugins)
          suzid6050
          all my files are in the correct place, no the plugin tab has disappeared from the top of sketchup. Still having no joy
            I have fixed your file and PM'd it to you.
            Do you also have progressbar.rb in the right place [Plugins] ?
            Basically I found your group a bit messy [exploded-nested/re-oriented/etc] and cleaned it up then it worked OK...
            • Chris FullmerC Offline
              Thanks TIG for stepping in and helping here. I'll throw in my observations here as well.
              Shape bender is really slow at breaking down internal components. So if your component you are bending has internal components or groups, it will go LOTS faster if you explode them all first. It can be slow you might think it was broken.
              And if you are having problems, please open the ruby console and then run the script and copy and paste all errors into this thread and then we can troubleshoot.
              If you have component spray (a different plugin) installed, please make sure it the most recent version. Previous versions had conflicts with progressbar, which in turn broke every script that uses progresbar, including shapebender. You might try removing component spray temporarily to see if that helps.
              If you can not select the straight line, you might need to right click on the model axis and choose "Reset Axis", and then try the script again.
              Keep reporting back here with specific errors, and exactly where the script breaks down, and we (I mean me and anyone like TIG who is kind enough to help me!) should be able to troublshoot most anything,
                arjunmax09
                i've the most recent one version of component spray and also tried resetting the axis but to no avail ๐Ÿ˜ž i'm attaching the video of what happens when i try to bend a simple cuboid....please ...someone find the solution to this problem
                the video where i try to bend the cuboid but to no avail
                  Hi arjunmax, that looks like a progressbar error. Or rather, it looks like progressbar mgiht not be installed? or else you actually have an old version of component spray.
                  Could you temporarily remove component spray from your plugins folder and see if that fixes anything? Also try opening the ruby console in the Window > Ruby Console menu, then run the script. Se what kind of errors it outputs. Thanks,
                    arjunmax09
                    Thanks Chris for this cool suggestion.... i removed the component spray from the plugins folder... and my Shape Bender is workin' absolutely fine..
                      That means you just need to search this forum for the most recent component spray, download and install it. The new version (now 6 months old at least) does not cause any conflicts.
                        arjunmax09
                        Thanks Chris for this valuable suggestion... the shape bender is finally working!!!! ๐Ÿ˜ anyway.... now what should i do to compononent spray???
                          Just go download the newest version of component spray here:
                          http://forums.sketchucation.com/viewtopic.php?f=323&t=11746
                          And install it. Shape bender will still work, and component spray will work too. It is a very good script,
                            Chris, I wonder if there is a way you can detect this old version of CompSpray? And then have a messagebox pop up telling them to upgrade it - avoiding this same question in the future.
                              Probaly about 10 pages of this thread are directly related to component spray.....that would probably be a good thing to add!
                              I'll have to track down a bad version of the script though. Anyone who has a bad version want to PM it to me?
                                arjunmax09
                                Thanks a lot Chris!!!! can't wait to download the new compo spray!!
                                  arjunmax09
                                  hey chris... is there a way to increase the segments of the bended object...?? I've attached a video of the object i want to bend...I think if there's no such option...adding one to your plugin will really improve it....
                                  Can I increase the number of segments in bending.zip
                                    It bends in however many segments are in the curve line. So if you want a fine detail in the bend, your curve needs to have finer detail. I made it this way so that the bending always matches up the curve that you are trying to fit to. It is more useful this way for bending a shape to an existing curves - like curving a logo onto a curved existing wall.
                                    So jsut try adding segments to your curve,
                                      arjunmax09
                                      oh is see..!!! Thanks Chris.. ๐Ÿ˜„
                                        arjunmax09
                                        @august said:
                                        Hi arjunmax09,
                                        @arjunmax09 said:
                                        ... is there a way to increase the segments of the bended object?...
                                        If that's clear, great. If that's confusing, try thinking of it this way:
                                        It works as if the Shape Bender picks up the object and the guide line at the same time and then bends, stretches, or shrinks the guide line to fit the target curve, bending, stretching, or shrinking the object along with whatever it does to get the guide line to fit onto the target curve. Depending on the shape of the target curve, the size of the bending object, and the distance between the guide line and the bending object, some parts of the object may be compressed while other parts may be stretched. But regardless of stretching or compressing of the object, one segment of the bent guide line is created for each segment of the target curve.
                                        I hope this helps,
                                        August
                                        Thanks a lot Mr. August!! I must say that was a really a complete crash course in "SHAPE BENDING USING SHAPE BENDER - EVERY CONCEPT EXPLAINED Thank you very much!! ๐Ÿ˜„
                                          Yes Thanks August. I find that this plugin works better the more you understand what it is doing behind the scenes. It becomes easier to get predictable results if you know how the plugin works, and how it tried to process the given shapes.
                                            August
                                            Yes, Thanks August.
                                            You're Welcome. Being able to make that kind of difference is a big part of why I got into Technical Writing.
                                            I find that's true for a lot of things, and it's part of my personal philosphy about writing instructions and explanations.
                                            Chris, have you or anyone else done any more of a tutorial on this than your video at the beginning of this thread? This has become one of those plugins that, for me, has become an indespensible part of what makes Sketchup magical and I'm thinking of puting it on my to-do list.
                                            I had just been using Shape Bender the day before "arjunmax09" asked his question, so how I think about how the tool works was very fresh in my mind. I've attached an image of the logo I used Shape Bender on.
                                            August
                                            3D text formed with Shape Bender, intersected with a sphere.
                                            โ€œAn idea, like a ghost, must be spoken to a little before it will explain itself.โ€
                                            [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                                            • 63
                                            • 64
                                            • 2 / 64
