    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
    • zieiosZ Offline
      zieios
      ok
      koooooooooooooooooooooooooooooooooooooooooooooooooooooool
        mike_in_ky
        Hi...
        I'm a newbie to SketchUp. I was looking at this topic and thought this plugin would benefit me in what I want to do with SU. I can't figure out how to download the plugin (FredoScale 2.0h).
        Thanks,
        mike_in_ky
        • Chris FullmerC Offline
          Hi Mike, it is in the very first post of this thread. Also read all the instructions. There is another file you will need to download and install along with this one to get it to all work,
            mike_in_ky
            Chris...
            Thanks. I finally found it and downloaded. I'll try installing later today.
            Mike
              mike_in_ky
              Chris...
              I was successful in installing Fredoscale 2.0 and worked with it a little. It's just what I wanted. Thanks for your help.
              Mike
                swzaw
                Thanks...It's wonderful Tool.
                • bagateloB Offline
                  bagatelo
                  Is it possible to access and to use the tools of great FREEDO for other scripts, enlarging Google Sketchup's API or something like this?
                  • fredo6F Offline
                    Do you have anything specific in mind?
                      alz
                      Hi Fredo6 --
                      Fantastic script, love being able to scale non-axis aligned!
                      When scaling, I saw the global unit position is displayed in the status bar as it scales. For example, taking a big box and scaling it down displays [~500] when it passes 500 in the Z-axis.
                      Is it possible to have the distance moved display as well? So, if the box's top face was at 700z and was scaled down to 500z, the status bar would also display [-200].
                      Or, better yet -- Have an option to swap the scale percentage in the VCB for unit distance. So, instead of the VCB saying 0.71, it would say -200. Having this option lets objects be scaled by the model unit for exact face location (rather than eyeballing a percentage).
                        arjunmax09
                        i'm having a problem using the bender tool in freedo scale... for instance.. in case of bending a cuboid...when the protractor comes.... instead of bending my cuboid .... it changes into a wedge....like a ramp...what shd. i do??
                        when you fail at something....you haven't really failed...you've found one way the thing will not work out
                          Jim
                          Tap the F4 key - that will turn on segments.
                          • H Offline
                            harshal kshatriya
                            thanks man.......
                            i love it.........
                            it working. 👍 👍 👍
                              arjunmax09
                              nothing happens, it opens the layer palette... I've attached a video of what happens when i try to bend an object..it will show what exactly goes wrong.....
                              Problems using fredoscale bender.zip
                                chrisjk
                                Another way to turn slicing on is to use the right click context menu once the shape is selected with the bender tool.
                                  AR-51
                                  Hi, I install Libfredo6,RoundCorner and Fredoscal, but I'm unable to use them in SketchUp.
                                  When I click on Tools>FredoScale noting happens. I also get no response when I click on Window>Libfredo6>Default Parameter.
                                  Can anyone with Window Vista help me? I don't get the option to unzip when I download the folders.
                                  Thanks for the help.
                                  Cannot access Fredoscal or RoundCorner from Tools>Fredo6 Collections.
                                  http://i601.photobucket.com/albums/tt93/Bestworldphoto/Sketch.jpg
                                  Plug in foulder
                                  http://i601.photobucket.com/albums/tt93/Bestworldphoto/Plugin.jpg
                                  • fredo6F Offline
                                    Do you have the icons in the Toolbar?
                                    Otherwise, can you turn the Ruby console on, and then select the menu LibFredo6 Default Parameters.
                                    Finally, can you check the content of the folders FREDOSCALE_Dir_20, etc... to verify they correspond to the footprint of the doc.
                                      d12dozr
                                      Fredo,
                                      Thank you for one of the most brilliant tools in Sketchup, I use FredoScale regularly.
                                      I am wondering if you could add the option to Box Stretching of multiple stretch dividers spaced equally by default, but also with the ability to manually adjust their position as well? Each portion would be stretched equally. This would be especially useful on say a window with multiple panes where now I stretch in two or more steps. Maybe the user could add dividers with F5 or subtract dividers with F6.
                                      Just an idea, and thanks again for all of your tools 😄
                                      http://goo.gl/f7ooYh
                                        Jim
                                        Hi Niels,
                                        A common problem happens when extracting the .zip files. Be sure to keep the folder hierarchy when extracting them.
                                        Can you post a screen-shot of your Plugins folder?
                                        Also, please post the error message.
                                          Windows tends to want to create a whole subfolder for the extracted files. I guess what Jim says is NOT to extract them into this additional subfolder but straight under the Plugins folder (keeping any folder hierarchy insidethe zip intact).
                                          Now the question arises - if this is the problem, SU should not recognise the plugin at all so there should not be any error messages. Did you also install the LibFredo library?
                                          • bmikeB Offline
                                            bmike
                                            Been playing with the 'bend' portion of this plugin.
                                            Took the straight version and made it into the bent version.
                                            http://lh5.ggpht.com/_0jkA5M3PGcY/S6fQwKc17WI/AAAAAAAAO5I/6GU41QET1Uk/s800/lakehouse-3-14-10.jpg
                                            http://lh5.ggpht.com/_0jkA5M3PGcY/S6fQqVX4bPI/AAAAAAAAO5E/5_bPdJRwL34/s800/lakehouse-3-14-10-bend.jpg
                                            I included the original 2d floorplans embedded in the model.
                                            Crashed the machine a few times - but I cleaned it up, simplified the original a bit... and it worked.
                                            I'd love to understand the math on getting the bend to meet a particular arc or radius. I drew a circle of the correct diameter and then eyeballed the model to get it close... which is good enough to see if clients are interested in the massing / concept - and I was even able re-link to LayOut so my views were pretty close and required minimal tweaking...
                                            • 56
                                            • 57
                                            • 5 / 57
