    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
      suzid6050
      no it doesnt change it just says please select the line on the red axis and wont let me select the line.
      • Chris FullmerC Offline
        Would you please open the ruby console in Window > Ruby Console.
        Then run shape bender. See if that window shows any errors. Please copy the entire text and past it back here. Hopefully it will be giving you some odd error that I can see and fix.
          suzid6050
          Error: #<TypeError: cannot convert nil into String>
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:158:in create_cursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:158:in make_cursors'
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:128:in activate' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:995:in select_tool'
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:995:in call' Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor' Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:173:in onMouseMove'
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor'
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:173:in onMouseMove' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165 Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165 Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in onSetCursor' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:230:in onLButtonUp'
          C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:230:in onLButtonUp' C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165 Error: #<TypeError: no implicit conversion from nil to integer> C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:165:in set_cursor'
            It looks like you have misplaced files ?
            C:/Program Files/Google/Google SketchUp 7/Plugins/clf_shape_bender.rb:158:in `create_cursor'
            line_cursor_path = Sketchup.find_support_file("line_pointer.png", "Plugins/clf_shape_bender")
            curve_cursor_path = Sketchup.find_support_file("curve_pointer.png", "Plugins/clf_shape_bender")
            default_cursor_path = Sketchup.find_support_file("default_pointer.png", "Plugins/clf_shape_bender")
            @line_pointer = UI.create_cursor(line_cursor_path, 15, 2)### line 158 ### line_cursor_path if nil !!!
            Do you have these images and other files in a folder called clf_shape_bender in the Plugins folder ???Capture.PNG
            • DVERGERD Offline
              DVERGER
              No success me too.
              I have this : 1%.End @ ? (1 of 5) Searching for objects to explode.
                Can those of you having these problems please check that all of the files are in the right folders first...
                Then try again and report back... 😕
                  arjunmax09
                  @dverger said:
                  No success me too.
                  ditto situtation like dverger.... happens with me too..... i've checked all my files but the problem still persists... the plugin keeps on searching but nothing happens....
                  when you fail at something....you haven't really failed...you've found one way the thing will not work out
                  • DVERGERD Offline
                    DVERGER
                    Yes, I found!
                    I have the progressbar in french (fr_progressbar.rb) so I copy this one in progressbar.rb and that's run.
                    http://www.crai.archi.fr/RubylibraryDepot/Ruby/FR_fil_page.htm
                      It's the name of the file it's trying to load fr_ progressbar.rb !
                      Still doesn't fix the other some files in the wrong folder possible problems...
                        arjunmax09
                        but i have the progressbar ruby script in English only ... my shape bender isn't workin' yet... 😞
                        • DVERGERD Offline
                          DVERGER
                          Mon dossier Shape Bender (dans le dossier Plugins)
                            suzid6050
                            all my files are in the correct place, no the plugin tab has disappeared from the top of sketchup. Still having no joy
                              I have fixed your file and PM'd it to you.
                              Do you also have progressbar.rb in the right place [Plugins] ?
                              Basically I found your group a bit messy [exploded-nested/re-oriented/etc] and cleaned it up then it worked OK...
                                Thanks TIG for stepping in and helping here. I'll throw in my observations here as well.
                                Shape bender is really slow at breaking down internal components. So if your component you are bending has internal components or groups, it will go LOTS faster if you explode them all first. It can be slow you might think it was broken.
                                And if you are having problems, please open the ruby console and then run the script and copy and paste all errors into this thread and then we can troubleshoot.
                                If you have component spray (a different plugin) installed, please make sure it the most recent version. Previous versions had conflicts with progressbar, which in turn broke every script that uses progresbar, including shapebender. You might try removing component spray temporarily to see if that helps.
                                If you can not select the straight line, you might need to right click on the model axis and choose "Reset Axis", and then try the script again.
                                Keep reporting back here with specific errors, and exactly where the script breaks down, and we (I mean me and anyone like TIG who is kind enough to help me!) should be able to troublshoot most anything,
                                  arjunmax09
                                  i've the most recent one version of component spray and also tried resetting the axis but to no avail 😞 i'm attaching the video of what happens when i try to bend a simple cuboid....please ...someone find the solution to this problem
                                  the video where i try to bend the cuboid but to no avail
                                    Hi arjunmax, that looks like a progressbar error. Or rather, it looks like progressbar mgiht not be installed? or else you actually have an old version of component spray.
                                    Could you temporarily remove component spray from your plugins folder and see if that fixes anything? Also try opening the ruby console in the Window > Ruby Console menu, then run the script. Se what kind of errors it outputs. Thanks,
                                      arjunmax09
                                      Thanks Chris for this cool suggestion.... i removed the component spray from the plugins folder... and my Shape Bender is workin' absolutely fine..
                                        That means you just need to search this forum for the most recent component spray, download and install it. The new version (now 6 months old at least) does not cause any conflicts.
                                          arjunmax09
                                          Thanks Chris for this valuable suggestion... the shape bender is finally working!!!! 😍 anyway.... now what should i do to compononent spray???
                                            Just go download the newest version of component spray here:
                                            http://forums.sketchucation.com/viewtopic.php?f=323&t=11746
                                            And install it. Shape bender will still work, and component spray will work too. It is a very good script,
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 59 / 64
