    Shift from groups
    renderpluginsextensions
    9 Posts 3 Posters 750 Views 3 Watching
    • F Offline
      fbo_bern
      hi all
      use SU 7.0.11018
      use Vray4SU 01.05.30
      look at the pictures. Why are the stones shifted?
      Even if I save and open the file again, nothing passes.
      Picture direct from SU:
      Picture 1 rendering:
      Picture after 2. rendering and after dissolve all groups and reopen the file. Still errors!
      Why does it indicate only so few stones?
      thanks for every help
      greez fbo
        Submit the model to support@asgvis.com to have them have a look at it.
        Could you also post it here so we can have a look at it?
        (I do have a suspicion, something that might be fixed in the new version. But I'd have to poke about with some scripting.)
          btw, how did you place the rocks in the model?
          • F Offline
            fbo_bern
            404 Not Found
            (rapidshare.com)
            I took 4 different stones. I distributed and scaled it. From it x times copies. Then with chris more fullmer tool the random scales and turned. Then all groups again dissolved. Now only each individual stone is a group or a component.
              Yup! That's it! There's something about how the transformation is done that your version of VfSU doesn't read well.
              • F Offline
                fbo_bern
                And which exact that is called? What can I make against it?
                  I think that Chris maybe found a fix for it. Not sure if he updated the plugin or not. Do you have the latest version of the plugin?
                  • F Offline
                    fbo_bern
                    Thanks. That could have been the problem. I downloaded a newer Plugin and made a few positive tests. Functioned up to now well. Thanks for the assistance.
                    • Chris FullmerC Offline
                      Interesting. Please let me know if everything is fixed now. I think the new version of the script functions better with SU and plays niced with rendering engines.
