    [Concept] Materials++
    35 Posts 21 Posters 14.3k Views 21 Watching
      you think it will work on macs?
      Good question. I hope it will. But you never know when making stuff with webdialogs. Heck - might even find it failing on PC.
      sigh
      Would not be the first projects of mine to fall apart due to flawed API.
        alz
        @thomthom said:
        @alz said:
        A UV key-nudge for transforms (position, rotation, scale). A reset transforms (position, rotation, scale, all).
        Can you elaborate on this?n Not sure if I fully understand.
        I just realized this branches over to UV editing and not the core idea behind your Material browser, so it might not make sense. But in the vibe of paint control, it'd provide a way to push and pull UVs via the keyboard. I think there's already some plugins out there that do this, so it's probably not the best suggestion for your time 😄
          I'll put it in the "Look at later" pile. But I think I'll skip it for the initial release.
          • C
            chrisjk
            Thom,
            A button to rotate a texture and duplicate it in the process through 90 degrees would be useful. It's easy enough to do on a single planar face using texture>position but for simply dropping a texture on a curved surface, I'd like to have the two orientations readily available.
              alz
              Ah -- here's one I found myself wanting this morning --
              A browser option to swap or condense materials. Select a bunch of materials in your list and swap them all for a different material.
                Ah yes, merge. Good one.
                • PixeroP
                  Pixero
                  WOW!
                  Me wants....
                  • bagateloB
                    bagatelo
                    My wish list:
                    -Procedural materials
                    -Something like Adobe Kuler
                      Far beyond the scope of this plugin and my own capabilities I'm afraid. Procedural textures is far from a light task
                      What is that? A tool that generate colour schemes? I've never used Adobe Kuler.
                      • Dan RathbunD
                        Dan Rathbun
                        @remus said:
                        A colour picker a la the native one would be very helpful.
                        I've long wanted a color picker for use with SU Ruby.
                        Had planned to see if Chameleon could be setup as a WebDialog to give us a quick and dirty picker. It's a free (BSD license,) totally Js based popup picker.
                        http://karmatics.com/chameleon/
                        I can get the native color picker to popup thru Sketchup.send_action but can't figure out how to get the return color value. (There is an object for Win32 that can be embedded in webpages for the crappy Win3.0 style picker on MSIE, but noone wants that one, and it's not cross-platform.)
                        So me thinks Chameleon might be a fasttrack solution. I wanted to make it a standalone WebDialog that could be called from ANY ruby, or from ANY WebDialog (via a callback to ruby.)
                        I'm not here much anymore.
                          RickW
                          You mean something like Repaint? I'm working on a GUI for this, with one-for-many replacement, and drag-and-drop selections. Early testing was going well, but my day job slowed development...
                          RickW
                          www.smustard.com
                          • pietervP
                            pieterv
                            Cool, sounds very interesting and promising!!! I have two suggestions, but I guess they are probably not possible. Anyway:
                            • A BIGGER color wheel then the standard one, which is realy not handy.
                            • The ability to use "Ctrl-Z" in the materials section!
                            This is my website:
                            Citypixels - 3d Visualisatie Architectuur
                            • EscapeArtistE
                              EscapeArtist
                              Ability to add a directory of textures to the library?
                                Ugh, the colour wheel - I really can't stand that thing. I don't see how people manage to use it? Oh well, I can add it to the list - but it won't be priority. In fact, the material editing is lower on the list - first comes the browser part of it.
                                Btw, what do you mean by Ctrl+Z in the material section? You want Ctrl+Z to undo changes in the model?
                                  I like this idea. 👍
                                  • pietervP
                                    pieterv
                                    Yes, that's what I mean. When I apply a material for example, I can not use Ctrl+Z to undo it. When I move one of the sliders to change a colors saturation for example, I can also not undo the change I have made.
                                    This is my website:
                                      YEa - Keystrokes aren't sent to SU while the focus is at one of the toolbar windows. Something that has annoyed me since I started using SU. Mostly when you undo changes to a model and when you undo a material change the focus automatically shifts to the toolbar window and you have to click on the SU window to make the shortcuts work again.
                                      • EarthMoverE
                                        EarthMover
                                        A paintbrush tool to apply materials while dragging across multiple faces. It would be a big help when applying projected textures with hidden geometry turned on for things like rounded corners and SDS meshes. With SU's poor UV capabilities most of us end up projecting multiple facing textures to organic geometry to fake it. The one click per face or drag select methods are a real pain with a lot of small triangles.
                                        Content Creator at Skapeup
                                        • pietervP
                                          pieterv
                                          I definitly second that.
                                          @Thom:
                                          Aha, so that's the reason! Interesting.
                                          This is my website:
                                            Got some experiments in regards to that area going on. 😉
