    Helix - not one full turn - HOWTO?
    33 Posts 7 Posters 14.0k Views 7 Watching
    • L
      lexje
      Done some more playing with 1001bit tools from Goh, and I think this will fit the bill.
      Will have to do extensive editing, but with drawhelix13.rb or spiralstair11.rb this would have to be done too anyway..
      Would still be glad to see how to build a helix in less than a full turn πŸ˜‰
      • GaieusG
        As I said, you can always break a helix - just like any other curve. I realise that these dimensions (324,xxx and 19,xxx degrees) are a bit "crazy" so to speak so I have been thinking hard how to achieve it (a simple segment count division would definitely not work - but it there were 18 treads and only 320 degrees, it would be easy).
        • L
          lexje
          I've been following the same line of thought..
          I did the math with numbers I got from a professional stairmaker, but I would like to 'build' the model in SU πŸ˜„
          I have to admit: I can find my way around SU more than average after a couple of months of SU-ing and sipping Aidan Chopra's excellent video's, but crunching these ruby plugins is a complete other cup of beans!
          I've also tried to add a couple of treads, just to have > 1, but no comma allowed..
          I'd be glad to listen / read how you would go about with 17 treads and only 320 degrees...
          Where would the difference be?
          Erwin
          • GaieusG
            No 17 treads but say 16 - and as you can see from the picture, there is a very lowest tread which is not even too much part of the helix but a kind of pedestal like step so I believe the cheat would not even be that obvious as that can be added later.
            πŸ˜‰
            • L
              lexje
              Well, the pictures I posted are from the stairmakers website, so they don't correspond with our stair to be. We'd need to cover a height of 3100 mm in 17 treads, so each riser would need to be 182,35 mm. Also, there's something as the 'walkline' (translated literally, maybe it should be line of walk (?)) This line of walk would indicate that each tread be 230 mm across at a radius of 650 mm...
              If I'm not mistaken you're thinkering of 16 or 18 to be a multiple of a pair?
              Erwin
              • GaieusG
                Well, true that not exactlythe same dimensions... Especially the "walkline" - I used completely different measures so this is just an example.
                The 18 is handy because 360 can be divided by 18. Then you take two of them and have a very similar number as your 324,xxx degrees (exactly 320).
                When working with segmented curves in SU, it is extremely hard to count with those long decimal digits.
                SpiralStair.skp
                  Had I realized you wanted to make 'spiral stairs' I would have suggested my 'Grow' tool...
                  Unzip this Grow.zip file and put the resultant Grow.rb into the Plugins folder and the growCursor.png into the Plugins/Icons folder [just as they are zipped].
                  The attached skps have some tutorials on how to make a helical [spiral] stair and also helices in general...Grow.zipGrowHelicalSteps.skpGrowHelix.skpGrowHelicalSteps.png
                    When making spiral steps there are often rules/codes to adhere to..
                    In the UK on narrower flights <1m [typically domestic or small commercial flights] you must have at least 50mm of plan-tread at the innermost part and the plan-tread on the centerline should be even for every step, and follow the rule 2R+G >=550mm <=700mm - where R is the Rise and G is the Going [plan-tread].
                    If you draw this in plan it limits the relative angle of adjacent nosings and effectively sets a limit on the taper angle between them = ~15degrees depending on the configuration etc...
                    For wider stairs you measure in from both edges [strings] 270mm and the same max/min pitch applies, 2R+G >=550mm <=700mm to the two locations
                    Any landings shall be the same length as their width measured along their centerline.
                    The minimum/maximum allowable Rise and Going varies with the building type too.
                    'Private Stair'[one dwelling] R >=155mm <=220mm and G >=223mm <=300mm [vertical pitch is also limited to 42 degrees - usually trapped by 2R+G rules]
                    'Institutional and Assembly Stair' R >=135mm <=180mm and G >=280mm <=340mm
                    'Other Stair' R >=150mm <=190mm and G >=250mm <=320mm
                    BUT AD-Part-M [accessible/disabled=all commercial/public building etc] R <= 170mm G >= 250mm
                    It's best to draw some test treads and place rotate a couple to see it they are right before committing to a complex 3D assembly...
                    β˜€
                      I have fixed the problems with drawhelix13.rb.
                      It now allows turns that are not whole numbers...
                      Here it isdrawhelix13_TIGd.rb
                        dylan
                        Nice information TIG.
                        Did you use another ruby for the stringer?
                        http://dmdarchitecture.co.uk/
                          No - it's made as a part of the tread and Grown... πŸ˜‰
                          • L
                            lexje
                            Hi TIG, thanks a tremendous lot for your input πŸ˜„
                            Greatly appreciated (Gaieus too b.t.w)
                            I did explain the spiral stair stuff though, see herehttp://forums.sketchucation.com/viewtopic.php?f=79&t=26214
                            I'll give your attachments a whirl soon and post back.
                            Although I must say my last experiments with Goh's toolkit are promising. (I've not found how to change direction of rotation clockwise/counterclockwise though)
                            One advantage I see in using Goh's plugin is that the treads are more detailed i.e. the outside of the tread are 'curved' instead of straight.
                            Nevertheless a couple of questions:
                            I'm native Dutch (Flemish) speaking, our stairmaker is French, and out here we're talking English, certainly with this kind of lingo I need some vocabulary help πŸ˜„
                            Let me first paraphrase the layout of our stairs to be:
                            HellicoΓ―dal with hollow core with R=200 mm
                            Riser = 182,3 mm for V1
                            Riser = 189,2 mm for V2
                            Going = 230 mm (Giron in French)
                            LF = Ligne de foulΓ©e ~= "walkline" ~= plan-tread (??)
                            Plan-tread @ R = 650 mm -> V1 = 3/4T + 1/8T +107 mm
                            -> V2 = 3/4T - 70 mm
                            I really think, in conjunction with what I learnt from the stairmaker, the best way is to draft a plan and side view (like the picture I posted before), and build your model from there, as I also found in a post from TaffGoh here http://forums.sketchucation.com/viewtopic.php?f=79&t=12511
                            I must say, although the ruby depot is a tremendous help, it's lacking responsiveness, and certainly for newcomers, clarity and a little more context.
                            E.g. most rb-scripts are already several years old and have often already been improved upon or contained within newer / other ones. Also a minimal documentation including ONE picture would often help to at least give an impression of what it's all about.
                            One request remaining:
                            For clarity's sake and certainly for others researching this 'specialized' knowledge - would you mind drafting a quick SU image adding the lingo 'terms' to exclude misinterpretation?
                            Thanks again for this great and responsive forum and all the help!!
                            Erwin
                            • L
                              lexje
                              Here it is[attachment=0:1sjnwqr5]<!-- ia0 -->drawhelix13_TIGd.rb<!-- ia0 -->[/attachment:1sjnwqr5]
                              Jeez, TIG you fix faster than I can think & write πŸ˜„))
                              Erwin
                              • L
                                lexje
                                B.t.w How do I get URL's right??
                                That is: to not show up as the full URL, but as a 'clickable' word?
                                I've had a look [url]http://www.phpbb.com/community/faq.php?mode=bbcode/]here[/url], but this doesn't seem to work..
                                Allthough the one below DOES work ?
                                Linking to another site
                                phpBB BBCode supports a number of ways of creating URIs (Uniform Resource Indicators) better known as URLs.
                                    * The first of these uses the  tag, whatever you type after the = sign will cause the contents of that tag to act as a URL. For example to link to phpBB.com you could use:
                                      [Visit phpBB!](http://www.phpbb.com/)
                                      This would generate the following link, Visit phpBB! Please notice that the link opens in the same window or a new window depending on the users browser preferences.
                                Erwin
                                • GaieusG
                                  I'm native Dutch (Flemish) speaking...
                                  Haha... We know that1s not the same (I had a Flemish room-mate when I went to an American univ. for a semester πŸ˜‰ )
                                  Anyway, for staircase building, TIG's Grow is definitely a good tool (and thanks TIG for a revised version or the helix plugin, too).
                                  This is not the correct way:
                                  But do it like this:
                                  [url=http://www.phpbb.com/community/faq.php?mode=bbcode/]here[/url]
                                  And the result will be this:
                                  here
                                  Edit: wow, does somebody read the FAQ???
                                  You have a bright future here, my friend! (Just look at what our other moderator, solo has in his signature about this)
                                  πŸ˜‰
                                  • L
                                    lexje
                                    Edit; wow, does somebody read the FAQ???
                                    πŸ˜„ As a matter of fact, I did search the FAQ, and it simply is not there (correct me if I'm wrong)Off course being the better than average user, I searched phpBB's faq for this... Hence..
                                    Solo doesn't seem to have too much of a Stoppelbaard πŸ˜„
                                    Erwin
                                      stefx
                                      I have just tried the plugin about Helix and it works perfectly!.
                                      So I want to thank you, guys, for the script and the info.
                                      Then I have a question:
                                      I would like draw my helix/spiral giving the radius and the pitch information but I would like to decide the height of the spiral.
                                      For example
                                      http://img211.imageshack.us/img211/65/49276923.jpg
                                      In the image I have a fixed height 11590mm and in the whole height I have to build my helix. I have tried with some parameters in terms of radius and pitch (the radius is fixed as well) but it is smaller.
                                      Any tips?
                                        Once the helix is made with the expected turns etc you can Scale it in the Z, typing in 1590mm [note the units 'mm'] - it then scales to that exact z-size rather than by a factor...
                                        πŸ€“
                                          stefx
                                          Thank you TIG.
                                          I have tried and it works.
                                          πŸŽ‰
                                          • P
                                            PlyrJames791
                                            πŸ€“ I'm currently working on a plugin that can produce a highly customizable curved or spiral staircase in SketchUp.
                                            I hope to release it soon, but in the meantime, take a look at this page:
                                            http://www.freesketchupplugins.co.uk/spiral_staircase.php
                                            As for a helix, I also have a tool that will make one. Unlike helix.rb or drawhelix13.rb, this will automatically give it a thickness based on a value you can specify. http://www.freesketchupplugins.co.uk/springtool.php
                                            • 2 / 2
