    Stop object from following cursor when using move?
    3 Posts 2 Posters 157 Views 2 Watching
      shazbot
      The title says it all, is it possible to stop the object your moving from following the cursor? Im trying to move one object (component). The problem is I can't anchor it to the corner because the object is blocking my view and it wount attach to the background..
      This is a rather serious issue when you want to be accurate and have rather tight spots to operate in. I tried googling the answer and searching these forums but it seems nobody has found this annoying enough, so here I am. ๐Ÿ˜
        shazbot
        Hi massio. Thanks for the quick reply, worked like a charm.
        • massimoM Offline
          massimo Moderator
          Hi shazbot, go in X-ray mode in order to view through your component (see the picture below) and check if the component is glued. If so: right click-->unglue.
