    How can I add new styles to SU on a Mac?
    14 Posts 4 Posters 1.8k Views 4 Watching
    • C
      CRSeventy
      I downloaded some styles shared by Lin. viewtopic.php?p=181498#p181498
      I want to try to use/try them and I can't seem to get them into the Styles window in my SU program.
      Kind regards,
      Chuck
      • C
        chrisjk
        Make sure they go in the correct folder:-
        Macintosh HD/Library/Application Support/Google SketchUp 7/SketchUp/Styles
        The Styles folder will also have sub-folders, create your own for imports if you want.
        • C
          CRSeventy
          Here Is what is looks like:
          • C
            chrisjk
            Chuck,
            I really don't know - I don't have such a menu item.
            I suspect it might be connected to some plugin you have - SketchyPhysics perhaps? If so, you might have misfiled one of the ruby scripts.
            • GaieusG
              No, plugins cannot affect existing SU windows. You should really be able to figure out I believe (I am on a PC so will not be too much of a help here).
              • C
                chrisjk
                Having had a quick look at the API docs (from a non-ruby coders viewpoint!) I agree with Gai's comment insofar as it refers to the kind of entry represented by --Runtime-- Of course, scripts can and do affect menus as far as plugin names etc are concerned.
                I suggest you post the question in the Developers forum.
                I don't think it's just a "Mac thing".
                • C
                  CRSeventy
                  Chris,
                  Thank you.
                  I have one more question. While I was trying to add these last night a "Runtime" sub menu popped up in the Styles menu. Any idea what that is or how to get rid of it?
                  Kind regards,
                  Chuck
                  • C
                    CRSeventy
                    @chrisjk said:
                    Chuck,
                    I have not added any plugins.
                    Kind regards,
                    Chuck
                    • jeff hammondJ
                      i managed to get the same thing to happen....
                      i did that by placing a folder named 'lin' inside another styles folder (the default styles folder)..
                      the folder that you named 'Lin Collection' should go directly into the styles folder --
                      if you have any folders inside of the ones already located inside the styles folder (color sets, default styles, sketchy edges, etc..) then the runtime thing will show up...
                      • C
                        chrisjk
                        That's intriguing, I put a lin subfolder inside the Default styles folder and I get no Runtime line but just a picture of a folder in the thumbnails of styles.
                        Baffled!
                        • jeff hammondJ
                          weird.. i'm now getting the same thing as you chris..
                          i can't get runtime to show up again.
                          • C
                            CRSeventy
                            What is this runtime? Do you folks think it will effect something?
                            What about deleting the whole program? Or plists?
                            Kind regards,
                            Chuck
                            • C
                              CRSeventy
                              [attachment=0:iy42ai4q]<!-- ia0 -->screen 5.jpg<!-- ia0 -->[/attachment:iy42ai4q]
                              I don't have any folders in other folders. Before I knew about how to add them I was just trying to drag them into the styles menu window or double clicking on them and Style Builder would open.
                              Kind regards,
                              Chuck
                              • C
                                chrisjk
                                Chuck,
                                I doubt very much that it's anything to worry about - I'd just leave it.
